Refresh951 - Latest 3L Build
#181
Did some tuning tonight on this motor with the Vitesse Stage V turbo and it looks like turbo back pressure is significantly less than with the Super65. Making the same power at about 2 psi less boost pressure
#182
Awesome! I recently had John make me an updated Stage 5 turbo to reduce back pressure and can't say enough about it. One bar of boost by 3k, endless power up top... Cheers!
#183
That's awesome, thank you for sharing the results. The S5 is very efficient and flows much more than the turbo you replaced, which explains your results. Even though it's a larger turbo, it is fast spooling without raising backpressure.
Jon mentioned he likes the spool up of the S5. What do you think of the spoolup and the power delivery?
Any chance you can share the dyno results and backpressure? I texted Jon, I may have an old number. If you do not want to post the charts here, would you or Jon email them.
#184
