Dry Sump pictures
[QUOTE=Paulyy;13053489]
I'd believe that. Even though some have got away with using stock components on track cars I have found that there are some parts that just have to be replaced with something larger, superior and contemporary. Not to shoot down stock parts but they were designed decades ago for a lot less hp than people are seeing nowadays.
The stock pump is good for what it is. But yes, for pushing these cars to that limit past 7k rpm. ive been told it will suffer from cavitation which i do believe. I dont know anyone going past 7k on the track?? you might.
When my oil pump was out, i looked at if there's a way to modify it to pump more oil.
Not much you can do with it really.
This is with 16v head though, yes?
7500rpm is attainable but you may not need it anyway going off your capacity!
You find pretty quickly that you don't need to wring it's head off (literally) to get moving quickly down the road. All the tq you'll have will get up and moving quickly. I tend to change gears based on sound, not any dials. You can tell when it's pushing the car too far. Sometimes based on gearing you do need to hold it in a gear longer than you'd advocate ordinarily but it's better than changing gears for a second only to have to change back down again.
It's weird driving a car with a quiet exhaust cause I never look to see what speed in going. Do it all based on sound the last few years.
Has anyone seen a 944/968 variant running dry sump and keeping all of the accessories like AC and PS? I'm building a high RPM 968 engine for my riv blue coupe and intend to use it for everything: weekend, road trip, autocross, track day.
http://www.customengineeredperformance.com/index.html
It directly mentions in the specs a custome bracket that allows use of a dry sumo with p/s and a/c retention. They seem to be well respected and I believe are rennlist members.
Albert Broadfoot (Broadfoot Racing) mounts the pump on the ps bracket which therefore retains the ac but requires manual steering. I see he uses some CEP parts and he’s built some nice dry sump engines in his time, might be worth giving him a call.
