Oil pickup line torque
Hi all, I'm sure I've missed it in the manual, but I can't find the torque specs for the oil line connecting the turbo mount/ engine suspension to the oil pan. This includes the 32mm banjo and the 2 small bolts at the top. Any info you have is helpful. Thanks
Tech Spec book page 29 says "55 + 4" ft. lbs. for the big banjo at the bottom, which I interpret as 59 ft. lbs. Don't recall the size of the upper two bolts off hand, but if they are M8 as I suspect (13mm socket) then they're 16 ft. lbs. (If they are M6, then 7 ft. lbs.) And welcome to rennlist!
