Project 944 Turbo
#137
#139
Off to Ebay..... that fan is so expensive brand new!!!!?!?!?!
on a happy note, i found the perfect keychain
#140
You've had some horrible luck but bit by bit it's coming together. Keep thinking of the good times because you will get there! One day you will look back on the drama and laugh. 😊
#141
Nice keychain
#143
#144
Have you put voltage to the fan motor before condeming it? It may be that the A/C button isn't pushed and it's the A/C fan motor side? Don't know I'm knew at this.
#145
If only one of the fans isn't operating properly, then there is something wrong with that fan, or it's plug/wiring or it's blown a fuse. Each fan has an individual little fuse, in addition to the big relay that controls them both. If both fans aren't operating, then the problem is further upstream in the wiring, temp switch or relay.
Mockingbird, before you do any trouble shooting, you should check the fuses for the fans.
#147
Just dropped by the upholstery shop to pass them some rubber gaskets for new windscreen (uuurrrgh $$$$$)
also, got to check on the progress of my seats. Hope it's not too bling. :x
#150
Soooo....... i got my overheating issue fixed.
I sent it to another shop to have a look and turns out there were 2 culprits.
Thinking one of the fans was busted, i ordered a nice working one from Lart. But still the problems persisted. Turns out...
1st, the fan not turning was most likely the relay/fuse. So i ordered a new one.
2nd, the original shop actually wired up Lart's fan the wrong way around... so it was blowing air away! from the radiator instead of pulling air in..... The new shop i turned to wired it up properly and with the relay just arriving yesterday, both my fans are now turning and the temp sits beautifully in the middle throughout.
BUTTTTT!!!!!! Now my headlights are refusing to pop up.... wtf mang...
