Difference between 2.5 and 3L belt tensioner?
Looks like it might work with wider roller..
I looked at all the pictures of S2 tensioner I could find online and compared it to mine. It appears identical apart from some S2 tensioners that appear to have steel base part.
Rainman
bumping this thread up for curiosity as i am looking for a tensioner...
noticed this detail though...aside from the slightly different PN and 2v/4v casting, look at the location of the bolt for the tensioner roller on the end of the arm - 2v looks further out, 4v is closer to the arm.
guessing the different head changed the belt path a little bit.
what's weird though is the 2v has a higher number -9 than the 4v -8. so the pictured 2v is a higher revision/later design than the 4v.
obviously the 2v/4v are stampings after the fact...maybe the parts are the same, but the location of the bolt hole determines 2v vs 4v application.
968 tensioner
Voith
This is a picture of mine off my 968. The 1989 NA , turbo and S2 used the style you have indicated.
Rainman
Thinking about it, the only reason I can think of a difference is because the 4V crank drive gear is larger diameter than the 2V gear.
The water pump is the same, so the nearby belt routing is the same.
Larger 4V gear would move the belt horizontally the width difference, which could be compensated with a larger tensioner sprocket, or the same size sprocket moved outward...
Will have to put 2V and 4V tensioner rollers side by side (or can anyone measure OD of the teeth on one)?
How hard would it be to adapt hydraulic 968 tensioner to 2.7 block? If I have to buy another tensioner, wouldn't it make sense to just go with the best option available?
Rainman
the 968 parts should all bolt on to the 944, but the main part is the lower 968 balance shaft bearing/power steering bracket.
apparently no one has spares (been asking around for at least 2 weeks), or those that do want crazy prices for them.
that bracket is where the "pivot pin" for the 968 arm is located.
Just checked ebay, about $200 per each used piece.. Shiet.
On the positive note, I have 968 belt cover already
Nice engine!
Great observation, I was eyeballing both from internet pictures for quite some time and didn't spot this difference.
I think spring version is much better than early version and this is the new age stuff cars use today. Definitely worth it imo just expensive.
Going back to the beginning of this thread I cant see if anyone touched on this but in that original PET the part # differences I believe are because all of the 8 valve NA and turbo cars from '87 model to mid '88 had the cast steel version of that spring tensioner it was heavy, the 16 valve cars had the alloy version and somewhere in '88 I noticed all the engines have the alloy lighter version!
Basic Sponsor
Rainman
Bringing closure to this thread.
i have a 4V and 2V tensioner side by side.
The springs are identical in diameter, coil count and wire thickness-- they should be identical spring rate, which is odd considering the much bigger belt on 4V.
However... the 4V lever length from pivot bolt to pulley bolt is ~1/4" longer than the 2V...4.0" vs 3.75".
This matches up to my earlier thought about the larger diameter 4V crank gear moving the belt horizontally outwards.
So, a 4V tensioner will work on a 2V, but the tension value might be off because the pulley isnt in the right spot.
But you shouldn't use a 2V tensioner on a 4V engine, the belt will likely be loose.
Jay Wellwood (12-09-2019)
