Rogue Tuning ECU Configuation?
I installed the M tune last summer and recently received Rogue's new ECU.
The map sensor is wired in the way it was done last summer. (I am not using the new plug configuration).
There are 3 switches together: WBO2/Alt. comp, Alt. Bias, Map.
WBO2/Alt. comp should be set to Alt. Comp
Alt. Bias should be set to ENABLE
The Map should be set to EXTERNAL
Are all 3 assumptions correct?
I am thinking the Map should be set on Sys Config because I am not using the new plug.
Small Business Partner
If you do not have a WBO2 hooked up to the DME, then:
WBO2/Alt. comp should be set to Alt. Comp.
Alt. Bias should be set to ENABLE.
The Map should be set to Sys Connector.
