People Running 4" Compressor Inlets???
1 Attachment(s)
I am trying to figure out what steps are needed to run a 4" compressor housing. I mounted my 3" yesterday and even though I have the smaller Nissan alternator the coupling is resting on the alternator. There is no way a 4" will work. I am curious what others did to get around this issue.
Attachment 923733 |
I bought 4" -> 3" 45degree black silicone coupler from ebay and use 3# fitler. But the turbo sits a bit further front than on stock 951.
Originally Posted by Raceboy
(Post 12163260)
Oh yeah, and because I'm tuned SD, there is no MAF pipe in that area to take up room. |
No MAF pipe would be a giant plus here! I might have to go that route. 4" to 3" might fit, but I am not sure. Going to have to do some test fitting.
Have you got that bracket to sit the alternator on. I thought it also positioned the smaller alternator in a lower position?
Patrick:
I don't want to loose my A/C, the one with the bracket is for an A/C delete car. I need to buy a 4" to 3" reducer and see how bad it is. |
I run SD so no MAF pipe. But I have a 4" inlet, 4" piping to a K&N filter behind the side market light. I'll try to get some photos. I have the quest alternator, AC and power steering.
Use the AC delete bracket to relocate the alternator to where the AC compressor is. This is a easy method which let's you use true 4 in plumbing. They make stock brackets and Lindsey offers one too.
Or you could mill the turbos inlet to shorten it up maybe? |
Originally Posted by URG8RB8
(Post 12164592)
Patrick:
I will not drive a car without A/C, sorry not going to happen. I will spend however much it takes to make it work with the A/C still operational. This is not a race car. It is a chic magnet and chic's don't ride in cars with no A/C! :)
Agreed, in hotter climates using a car without A/C is pain and it takes half of the fun of driving a fast car away if you sweatduring drive.
But most of the time over here it is not that bad, it is just few weeks in mid-summer when temps are 30-35C range. And chicks definitely ride here in cars without A/C :D |
(Post 12165279)
Who needs AC when 944 is so good aerodynamically that you can drive around 200km/h with both windows rolled down :)
I have 4" then with a 4" - 3" reducer to maf.
None of my Porsche came with A/C from the factory but if they had, I would not delete it.
