Zeitronix ZT2 guru's
Hi
I am about to install my ZT2 and just want to confirm I have got the wiring correct.
I am going to display TPS on bottom left of display, Boost(via user 2 input) on top left. AFR on top right although yet to get bung welded in. EGT wont be used at this point.
So below is how I plan to wire up going off Tom's write up and the wiring diagram that came with my(newer model to Tom's) ZT2
ZT2
pin1 red to DME pin 18 (red/yellow)
pin2 not used
pin3 green to DME pin 21 (green/black, RPM signal)
pin4 orange wired to pin6 yellow to dispaly TPS
pin5 not used
pin6 yellow wired to pin4 orange to display TPS
pin7 black to DME pin 5 (brown, ground)
pin8 white/brown user 2 input wired to Green MAP sensor from boost gauge
pin9 not used
pin10 Grey to pin 22 on KLR(white/green, TPS)
pin11 not used
pin12 not used
TIA
ZT2
pin2 not used
pin5 not used
pin9 not used
pin11 not used
pin12 not used
TIA
I used Tom's instructions and found them very helpful:
http://members.rennlist.com/tom86951...nd%20wires.htm
Thanks Shawn. That(Tom's write up) and the ZT2 instructions are what got me to the above. I guess my main concern is using just the signal from my boost gauge/map sensor, as that s nearby and easy to tap into, rather than using the Zeitronix MAP sensor. This will allow me to display TPS and although that is not really needed, I think it will look cool and is something not displayed elsewhere. The other option is to use Zeitronix MAP sensor and buy another sensor and say monitor Oil P or something. As the car has that already it seems redundant. Anyway just want to make sure my logic on the wiring is ccorrect
I heard back from Zeitronix and have decided to just use their boost sensor instead. My foot can tell me my TPS and it leaves me scope to add something later if I want.
Might consider getting Vitesse's V-Knock now (it's cheap) and logging that on one of the spare inputs. Combining wideband AFR readings with knock monitoring is definitely worthwhile.
Hi Tom
I was going to use display to have TPS on bottom left and use the top right user 2 input for boost but have now decided to use the Zeitronix MAP sensor to have boost on lower left and won't display TPS(just log it). I have already bought the Zeitronix MAP sensor so figure I may as well use it. I also have their USB adaptor and an old Sony P series laptop, good to go for data logging.
I have contacted John at vitesse and placed an order for the V-knock. I think that is a great idea. I assume I would use the pin12 Blue input on the ZT2 ? Are you using V-knock ?
Hi Tom
See first post in this thread, for example, to see how they all display at once.
https://rennlist.com/forums/944-turb...g-success.html
Yes Tom I was going to display TPS on rectangular display(thats what I have) but now I am not going to. I may as well tap pin 7 on DME to Blue pin12 on ZT2 to get my MAF signal, as I am literally about to wire it up now. I may as well do it now, while I'm in there
cheers
cheers
cheers
cheers
Actually thought of doing that for user 2 input, as will use that for V knock and don't want to pull dme & klr again if I don't have too, although installing V-knock will probably require it anyway lol. Will install a connector midway along blue user 1 input too. Thanks for the tip Tom, and all your help
