ISV and other rubber hoses under intake
So, I have ripped out all of the old hard plastic vacuum tubing, and replaced it with new vacuum tubing/ t's, and zip tied the ends for a better seal hopefully.
For the ISV, do I just bite the bullet for factory pelican parts/silicone from lindsey?
Also, trying to figure out what folks here did for the vacuums lines(3/4") that run from along the firewall to the brake booster/check valve.
Will normal vacuum tubing/gas line work fine here?
Thank much.
Thank much.
I bit the bullet and got venturi delete, AOS hose, from LR. I also fitted Laust vacuum manifold. I also got the brass T for brake boost line from Laust.
You can see the vacuum manifold in this pic
Replacing the hard pipe tree under the manifold is well worth doing and LR stuff makes it pretty easy
