UPDATE: It's running and I have boost!
Well, I replaced every piece of vacuum hose I could find and replaced the cycling valve with a MBC and what do you know, I have boost! It still wants to cut out/surge when I have it under load but it's a big step in the right direction. I also have a weird "clanking" noise when it's idling that is odd but I haven't been able to track down yet. It's gone when I'm moving so I think it might be clutch related. I guess we'll see. I have a few other things to track down still and need to replace the fuel filter and all the fluids, but I'm almost caught up with maintenance.
Drove it for only the second time today. So much fun, even with the issues. I also got rid of most of the exhaust leak so it's pretty quiet and picked up some good used Koni's for the rear. Having rear shocks makes a world of difference too! ;-)
Anyway, wanted to share my joy with everyone. Still couldn't tell you what fixed it, but the combination of things certainly helped! (my guess is the cycling valve)
I used the factory spec for plug gap, so I don't think it's that. I almost think it's due to the use of the manual boost controller. From other cars, boost is usually dependent on throttle position. With the MBC, boost is dependent on RPM's. Could it be that it's getting more boost sooner than it's expecting and it cuts out?
Still have so much to learn, but I've been driving it like crazy and it seems to be getting better. I think the bypass stuck a couple times because I wouldn't be able to make much boost and then there would be a "click" from the right part of the car and it would make boost. The more I drive the better it gets... it probably hasn't seen much exercise over the last few years.
That's entirely possible. I thought it was from up front but sitting in the car it sounds like it's behind me.
