944 Turbo motor value
Old 11-20-2014, 10:52 AM
dlc356
dlc356's Avatar
Default 944 Turbo motor value
I've been getting parts together for my 5.3 swap. I'm planning on selling the motor & harness etc. How much should I expect or try to sell it for? It has a few minor leaks on some rear seals, the DME needs to be fixed (I found rebuilt units for $350 online w/core exch), prob good idea to do water pump etc while it's out, etc... I want to be fair but don't want to short change myself either.
Old 11-20-2014, 11:49 AM
V2Rocket
Rainman
V2Rocket's Avatar
How many miles, what leakdown, does it run, etc...
Where are you?
Old 11-21-2014, 11:44 AM
dlc356
dlc356's Avatar
Sorry for the slow response. 159k, it does run but the computers need to be fixed. The compression and leak down tests should be done today. I'm in Birmingham, AL.
Old 11-21-2014, 02:53 PM
jtsporsche
jtsporsche's Avatar
For someone looking to turbo an n/a, if you're including all turbo parts( turbo, intercooler, intake peices, exhaust, etc.) 1k at the most. 156k miles isn't a huge amount on these motors if well maintained, but its not exceptionally low either.
My. 02 cents
Old 12-09-2014, 03:52 PM
dlc356
dlc356's Avatar
I'm going to be selling the motor, turbo, accessories, & wiring harness... Compression test was 160-170 across the board.
Old 12-10-2014, 10:48 AM
Van
Van's Avatar
I'd hazard a guess of $500 to $1k.
Old 01-05-2015, 12:27 PM
Alan 91 C2
Alan 91 C2's Avatar
Did you sell the motor?
Old 01-05-2015, 02:01 PM
dlc356
dlc356's Avatar
It's still in the car. I did get some good pics and have the comp/leak down #'s
Compression
#1 155lbs
#2 170lbs
#3 150lbs
#4 170lbs
Leak down
#1 4%
#2 4%
#3 3%
#4 2%
Old 01-05-2015, 03:18 PM
Alan 91 C2
Alan 91 C2's Avatar
What is your time frame to remove the engine. I have an open time line for a replacement engine. I am going from n/a to turbo, so I will need all the pieces, except the intercooler.
I am in Atlanta and can pickup the engine.
770-368-9550
Alan
Quick Reply: 944 Turbo motor value
