cost to repair a battery tray
I just bought an 88 turbo with a hole in the battery tray, The battery tray looks fine with the exception of a few small holes right where the tray meets the firewall. What would it run approximately to have it cut out and weld a new piece in? I bought the car knowing there was a leak and a bad computer, but it was too good a deal to pass up.
Location: Hawkinsville / Perry, Georgia, RETIRED USAF GO BLUE
1 Post
Hi Cory, Use a wire brush on your drill to clean off the rusted area good and fiberglass over the old rusted area. Some people have cleaned and painted the battery area with Truck Bed Liner. Welding in that area may burn wiring for the DME.
Cheers,
Larry
Cheers,
Larry
I documented my experience with this here - I had several threads on rennlist about it too. (EDIT: I found some more pics of my car on the website of the guy that did the work, including one showing the car with the old tray cut out)
It can be done without any damage to the wiring or anything else, but you have to be prepared to spend a lot of time removing things. I didn't have to remove the main wiring harness from the firewall - but the guy said if it had been much worse it probably would have been an engine-out job.
I highly recommend doing it this way. Do it properly once, forget about it forever. If you do anything else you will always have to worry about leaks.
I would not suggest doing a fiber glass band aid. To do it right, you have to re-weld metal. This can be done without dash removal but one has to be very careful as there are plenty of cables under the panel. You need a competent welder to perform this. To play it safe, you can spend the extra 15-20 hrs of dash removal and all other bits.
When I bought my car it had a few pinholes near the firewall (and some other thin spots). I used some POR21 epoxy putty and formed a thin layer that was painted over w/ rattle can silver. Looks fine 15 years later and no leaks. Total cost (at the time ~$15).
Last edited by jerome951; 11-17-2014 at 08:33 AM. Reason: specified putty, not epoxy paint
I'd say evaluate how bad yours is. If its too bad, weld it, if it's minor then there's a million cheap hard sealers that work just as good. Take pictures, battery out and well help you out
On my '84 I had lots of pinholes and a few holes that were slightly larger. I used Por15 PorPatch (after cleaning all the rust off with a wire wheel).
And.... don't forget to install a battery vent tube to keep that battery acid away from the sheet metal. Run the tube down to the ground.
The putty also helps by raising that area so water doesn't collect there any longer.
I know you used a different product than I did, I was just giving a +1 to the fact that pinholes can be fixed inexpensively. I guess I can also give a +1 to POR products in general. I'll have to try that POR21 epoxy putty.
The hole I have is about the size of a quarter, I'm just going to get it welded and forget about it. Does anybody have any recommendations for a good body guy around north nj?
just carbon fiber it, thats what I did, its super simple and kinda looks cool.
all you need is one square of carbon and one square of glass just lay it in there and wet it with resin, and for about $40 youre done and dont have to worry about it in the future.
You are in luck. I had a similar issue in my can and the shop is in northern NJ. PM me and I can point you to the place.
One other thing: does your car have airbags? Because the passenger airbag sensor is pretty close to the battery tray/firewall area. It's hidden away up there in the corner. I have had mine disconnected since I had this work done. If I was going to reconnect them, I'd probably replace that sensor, what with all the welding and plasma cutting going on in that area.
