Knock log
Knock log
I attached a log file of part of my morning commute. Im trying to get a better understanding of the knocks I'm seeing. Anyone care to take a look?
In the past I have tried to lower the ignition settings where the logs show a high knock but I got as low as 13* without any change in knock count. Not sure if the knocks in this log are even anything to worry about. Opinions welcome!!
This is a .dat file from an Electromotive ECU using the stock bosch knock sensor. I think you can use any log viewer to view. 93 octane and outside temp is 52*.
Thanks.
Thanks.
