Holset hy35 Install....
Old 10-01-2014, 02:40 AM
Alpineace
Alpineace's Avatar
Default Holset hy35 Install....
well I just picked up an hy35, and it seems the turbine flange mounts to the crossover flange.... SO what else do I need to know to put this together?
it seems to bolt to the turbo mount/oil drain, do I need a restrictor OR a spacer?
and what about the downpipe/turbine housing?
I know this uses a vband to hold the turbine housing to the Center.
Old 10-01-2014, 10:19 AM
V2Rocket
Rainman
V2Rocket's Avatar
Does it bolt onto the turbo mount without any grinding?
Old 10-01-2014, 10:41 AM
blown 944
blown 944's Avatar
How could the flanges mate? The holset uses a t3 while the stock turbo uses the odd kkk inlet.
I have machined the v band and skme other areas to fit the hy to a stg 5 garret .63 hotside. On a DSM
I don't think you'll get away with using the holset turbine housing since it's a lot longer.
Do you still have the 924 turbo car?
Old 10-01-2014, 02:46 PM
Alpineace
Alpineace's Avatar
well what i meant is the t3 flange seemed to match up to the crossover flange? I just held it up to it, didnt actually try to bolt them together.
But yes I was kind of wondering about the downpipe clearance.
can you show me about the t3 housing? I need something cheap to work, temporarily. just curious but why the .63 vs the .82?
yes sorry i forgot to respond about the 924 been out of town for a while. Not quite sure what I want to do with it. If I can get this 951 running Ill decide, on the 924
Old 10-01-2014, 10:40 PM
Alpineace
Alpineace's Avatar
also BTW since the holset is an oil only turbo, does that mean i can use a 944NA new coolant res?
Old 10-01-2014, 11:42 PM
blown 944
blown 944's Avatar
yes you could eliminate all the coolant lines.
i had to grind some notches in the vband portion of the hy center section to allow the bolts to go through to the garret hotside,
i used the .63 bc its what i had fabbed already. it ran 11.8 at 116 at 23 psi in the talon, so pretty good for a base startingf poin
Old 10-02-2014, 12:29 AM
Alpineace
Alpineace's Avatar
are you not currently using it? can you show me exactly which hot side you used? or where I can find one?
Old 10-02-2014, 01:13 AM
blown 944
blown 944's Avatar
I'm using the hotside now. Not sure what direction I'm going with this car right now. Ill send you a pic of the center section. You can usually pick up garret hotsides on ebay or you can get them direct from garret.
Old 10-02-2014, 02:03 AM
Alpineace
Alpineace's Avatar
darn can't seem to find a cheap one.
However I did see these: they mount with V band and comes in a .73
http://www.ebay.com/itm/Turbine-Hous...fd8fdf&vxp=mtr
http://www.ebay.com/itm/Turbine-Hous...8e9060&vxp=mtr
Old 10-02-2014, 10:12 AM
blown 944
blown 944's Avatar
Those aren't for a holset?
Not sure how they would match up. They don't look like they are right. Yiu could risk it though.
Old 10-02-2014, 01:59 PM
Alpineace
Alpineace's Avatar
well they mount to the center section with V band just like the holset.
can you show me those pics?
Old 10-02-2014, 11:59 PM
Alpineace
Alpineace's Avatar
kind of surprised more people arent chiming in?
Old 10-03-2014, 01:15 AM
Weston Dillard
Weston Dillard's Avatar
I am about to do this with a 35 or 40, so watching and learning.
West
Old 10-03-2014, 02:23 AM
Alpineace
Alpineace's Avatar
here are the specs of the HY35
Specs that I obtained from calling Holset (these #'s are 100% accurate for one of the turbos coming my way).
Compressor inducer: 54mm
Compressor exducer: 78mm
Turbine wheel: 58/65mm
Turbine size: 9cm2 (or 10) depending on how it's measured. I'll get exact specs when the turbo(s) arrive here. The compressor wheel sizes are similar to a GT3076r and the turbine similar to a GT3276. Compressor and turbine trim are 48/79 respectively.
I've talked to a couple subie and honda guys and everyone who uses it seems to love it. Only time will tell I guess. I'm hoping for full boost (~8.7psi) by 3000rpms.
Old 10-03-2014, 02:25 AM
Reimu
Reimu's Avatar
If you're only running 9psi of boost why even move away from a kkk turbo?..
Quick Reply: Holset hy35 Install....
