Wossner custom 3.0 pistons.
#31
The problem is there's shops around that say they can do it but how do you know, maybe Sunnen can advise who has the right know how ?
#32
Boring and honing
Mantissport has the access to a machinist which has prepped over 15 blocks, with no issues. I know this does'nt help the guys overseas, but there is hope.
#33
May be Baz Hart might be able to help with alloy liners. He was extolling the virtues of an alloy solution for road cars - it's just a question of settling on what type of plating you'd like.
I don't think he'd install third-party/client supplied liners as he wouldn't want to responsible for the consequences of parts supplied by someone else.
#34
Hartech are very busy at the moment apparently. Baz had a turbo block sleeved to 3.0 and a set of 16v pistons a while back but when I asked how much he didn't reply.
#35
To answer the original question - I can buy Wössner pistons directly from the factory.
Regarding sleeving - wet and dry sleeves can be done in Sweden too along with correctly spec'ed JE pistons.
#36
Thanks Gustaf.
I've contacted the UK Sunnen dealer to try and find a good machine shop experienced with Alusil. If I'm not confident in any I'll have to consider sleeving.
Paul.
Paul.
#37
Somebody should contact KolbenSchmidt. If they don't have the know-how, nobody does.
