noob may have seized his engine
...talking about me. first time removing intake manifold on my 86 951 - purpose was to replace cycling valve, which was busted. got everything off ok without stripping any bolts (well i did but not one that mattered), changed the CV and some vacuum lines (the ones connecting to it mainly). reassembled everything without issue, or so i thought. got fuel rail back on and verified firing order for wires - went to start engine. just cranked, so i verified plugs one more time, noticing that i didnt have contact on cylinder 2. made sure all plugs were seated properly, and went to try to start again. this time it sputtered and died. tried to start again. this time i heard an absolutely terrible clunking sound, and the engine abruptly shut off. has the engine seized?
Hard to tell from that description. Pull the plugs out and slowly turn the crank.
Did you mess with any belts? Otherwise, it doesn't sound like something that would seize an engine, but Voith is right. We need a LOT more info.
yes i followed the firing order from clarks garage. verified several times ... i dropped one bolt - when i was bolting the IM back on i used the wrong bolts originally in the rear (where the two 5mm hex bolts go), so when backing out to replace i dropped a 10mm bolt down into the depths somewhere, wasnt able to find it. i dont see how it could have gone into the head though as everything else was already bolted back together. unless there is some intake or some port exposed down there that im not aware of...btw no belts were touched.
just found this thread - im screwed. same area I was working on when the bolt fell. except I didn't take the head off..
https://rennlist.com/forums/924-931-...ining-nut.html
Professional Hoon
Follow these steps.
1. Pull the spark plugs out
2. put a socket on the crank pulley and turn it clock wises.
if it jams up. stop. Then turn it anti clockwise.
you may feel it's the piston if you've gotten a bolt in the cylinder. or you'll hear the bolt if it's in the fly wheel.
I used to have a starting problem that sounded like a sick 'thunk' and turning over just stopped. We haven't fixed everything yet, but when we did our vac lines and got our injectors and rail cleaned and rebuilt we seem to have the problem much much less.
I have a thread on here somewhere i posted a video of the sound for diagnosis help. May be you can find it and it might help answer.
The check of the flywheel would be good too, I just don't think that is as likely.
You would have to be MEGA unlucky to have that bolt fall into the bell housing hole, unless you were working RIGHT over that area. Could it have, yes, but I bet against it. Do what Paulyy suggested first. My guess is some other reassembly oops. Check fuel lines/damper/FPR. Check the vac lines to those components. Usually, it's something really simple. Check the IC couplings as well. My guess is that you have something loose, rather than a bolt in a hole. Hopefully, anyway.
