Cyril’s build – Lighter and Wider – Thanks to IFC Racing
Old 05-21-2014, 03:14 PM
  #106
disasterman
disasterman's Avatar
Nice!
Old 05-21-2014, 03:52 PM
  #107
Charles A. Toupin
Charles A. Toupin's Avatar
Cyril,
I do have your straight pipe exhaust with me... (just so you know you can come race with us)
You need a front splitter and some stickers too!
Otherwise, just drive this thing!!!
How was it with Dave Karl behind you in his 993 (first pic)
c.
Old 05-21-2014, 05:08 PM
  #108
Dutch944
Dutch944's Avatar
Looking great!
Old 05-21-2014, 08:06 PM
  #109
Cyril
Cyril's Avatar
Originally Posted by 333pg333
Good for you Cyril...you haven't wasted any time!
Looks like your exhaust is hanging a bit low? Also, it would be good to try and get your guys to work the rear of the fenders into the valence a little more.
You are right Patrick, I just need to figure out how to fit a 4'' exhaust with the tarett sway bar!
The rear is not finished. My plan is to install a rear diffuser and remove the Turbo valence. So the exhaust is also in the equation. I need to build something like Duke or like this...
Any input on this is welcome!
Old 05-21-2014, 08:23 PM
  #110
Cyril
Cyril's Avatar
Originally Posted by Paulyy
That looks awesome! need some stickers on it!!
I am working on it! :-)
Originally Posted by gruhsy
The front end on your car is the best looking track car I have seen. Like it very much
Thank you so much gruhsy!
Originally Posted by 964-C2
Very nice!
Do you know how much lighter and how much faster (lap times times) than earlier?
Sorry, no lap time as my Go Pro died during the first run! POS!
I am faster this year but as Charles mentioned, I am not pushing enough! ;-)
Originally Posted by rlm328
That much white is blinding, ya need some graphics.
The next time you have the front end off you may want to consider putting in some wire mesh to keep the larger chunks of track debris from getting at your radiators.
Ok, stickers are higher on my to do list now! ;-)
Good point for the mesh!
Thank you again guys!
Old 05-21-2014, 09:36 PM
  #111
333pg333
333pg333's Avatar
Looks like a pretty good diffuser. I would guess not cheap either. Would you get them to make it or do it yourself?
For an off the shelf splitter I'd look at the one of Jim's sold through Good Aero.
Looks to be easy to get on and off. On the other hand it appears that you could get something made up by those 666 guys that might be even more effective. Aero is a black art and some minor changes can give decent rewards.
Old 11-24-2014, 04:44 PM
  #112
theamsoilguy
theamsoilguy's Avatar
Can you show how the duz fasteners are fastend to the fiberglass parts? I have to install my Broadfoot kit. I know that if I rivet the fasteners to the fiberglass the rivets will prevent it from fitting flush on the sheetmetal.
I thought about riveting from the inside out, but then I would have a mess on the visbible side. Did you use something other than rivets?
Old 11-24-2014, 06:49 PM
  #113
Cyril
Cyril's Avatar
good question!
I found 3 options.
The usual way is to use solid rivets but it is difficult to do it on the edge of a fiber glass part.
Another way is to grind the back part of the rivet flush to the fiber but it is a little tricky and fragile.
The most popular way is to simply drill a hole on the other part (spring side) to be able to receive the rivets.
I chose to do a compromise between the 2nd and the 3rd method. Instead of holes on the receptacle side, I just flared the other side. I actually modified a clamp and made my own flaring tool like this one...
http://www.lasaero.com/site/products...e?id=V01XC83F9
I will try to find pics for you.
Quick Reply: Cyril’s build – Lighter and Wider – Thanks to IFC Racing
