After market fuel rail
Hello, im in the market for an aftermatket fuel rail! Any recommondations? I know lindsey and speed force. Just want to see if there are any other options? And which one you guys would recommend thanks !!!
Is SFR even still in business? e: I guess so, last time I checked their website it was down.
CEP: http://customengineeredperformance.com/
Front page of the website, second picture from the bottom on the left. Uses a damper at the end (looks like a Marren but CEP might make his own?).
From TechnoDuck's car:
https://rennlist.com/forums/944-turb...l-install.html
It can be done with a 'saddle adapter'. I think Dave offered one as an optional 'add-on' for the kit, but you can purchase one that will work with it.
This is basically the same thing, and compatible with the stock FPR.
http://www.bahnbrenner.com/vw_audi/p...il_FPR_Adapter
Here is the above product mounted on my car with the CEP rail. Line routing is a mess as this was for test purposes, but you get the idea.
or with an adjustable regulator..
have not seen a saddle adapter before. looks great. my one complaint with the LR+stock fuel regulator setup I have is the adapter the fuel regulator sits in. it doesnt seem nearly as a strong as i would like. 1 grub screw holds the adapter together and if it loosens up, fuel spits everywhere.
CEP's fuel rail is completely awesome.
Different height mounts for it depending on your fuel injectors. Taller Bosch injectors vs shorter more modern ones. Eliminates the adapter hats that go on top of the injectors.
