ball bearing turbo replacement for k26/6 ??
7th Gear
what is a good ball bearing turbo replacement for k26/6. looking for a little more HP and a little less lag. I have an all stock 86 944 turbo except for 3in ss exhaust.
garret gt30r (3076) .58 a/r will not bolt up directly, needs to be clearanced on exhaust side slightly and on turbo pedestule mount. you will also need to get oil feed lines and mounting adapter. Don't forget to tune. also need to change the flange on upipe. if you want something plug and play thats ball bearing, it won't last long, it will be hybrid... etc.. get something new, or leave it alone and free up your exhaust, remove cat, get a larger intercooler, get rid of the old cycling valve and change your wastegate. get the right chips you want , right fuel and right timing (fixed unless you know what to do)
Check out lindsey racing. The super 48 or 53.
I agree with The above comment there are a lot of things you can do before changing the turbo. I changed the waste gate and put a 3" exhaust and I'm happy with the improvement. Changing the turbo is expensive.
Location: Bangkok, Thailand, Milpitas, CA & Weeki Wachee, FL
1 Post
I have a turbonetics stage III hybrid bought in 2001 still perfect and I love it. Quick spool and good power. It is on a daily driver. Never had an issue. It was from your area, Huntley Racing in San Diego. Went down and picked up from Derek.
If you want better spool and a bit more top end, may I suggest a maf kit ie m tune. This will make a dramatic difference especially on a stock car with an exhaust.
As others have said there is a lot more to a turbo upgrade than just bolting on a turbo.
7th Gear
whats the difference between a Billet wheel and compressor wheel? Thanks for all the great feedback members. I just read that a ball bearing turbo would start to spool earlier then the journal bearing
