VW/Audi 07K (2.5L 20V I5) Swap Thread
Old 04-15-2019, 01:28 PM
  #1096
vt951
vt951's Avatar
Originally Posted by senior_squishy
I honestly don't blame you, my model wasn't near as accurate as yours and the webbing took forever! What all do you think will be needed to be done to the pickup? Think we'll be able to utilize the stock mounting point?
Yes, stock mounting point for the pickup will work, but the pickup will need to be modified from that mounting point down. This pan will have a deeper/larger capacity sump than the factory one, as well as trap doors.
Old 04-15-2019, 02:04 PM
  #1097
RoyaleWithCheese
RoyaleWithCheese's Avatar
I'm assuming we will need to send in a core for the pan to be modified?
I'm holding off on buying an engine due to limited storage space but I can start searching for a cheap used pan if I'll need one to send in once the production of the oil pans is ready to go.
Old 04-15-2019, 05:05 PM
  #1098
vt951
vt951's Avatar
Yes, you can send me yours, but I'm not sure I'll be able to keep track of whose is whose. I will probably just buy a few extras and do a core refund program.
Old 04-15-2019, 09:53 PM
  #1099
JWebber
JWebber's Avatar
I was thinking about picking up a spare engine or two myself . I could send you the uppers to help with the core stock pile .
Old 04-15-2019, 10:20 PM
  #1100
vt951
vt951's Avatar
Thanks Joey.
How much do you guys think the core amount should be?
I don’t know if you’ve pull any of these pans off yet, but I’ve done a few and it’s a little bit of a pain sometimes. I think it’s because the front and rear of the casting are sandwiched in between a front and rear gasket. And the top is sealed to the block. The last one I did required a lot of persuasion with a rubber mallet.
Old 04-15-2019, 11:08 PM
  #1101
JWebber
JWebber's Avatar
If you pull the front pulley and seal plate off ,,,, it drops like panties on prom night
Old 04-16-2019, 12:48 AM
  #1102
Cjar
Cjar's Avatar
I decided I don’t want to wait for my TIG skills to improve and picked up a used TT RS turbo. Machining to fit the 07K head looks easy enough, but is there going to be an iAbed option? No sense reinventing the wheel.
Craig
Old 04-16-2019, 12:54 AM
  #1103
hinton
hinton's Avatar
Craig
iabed DOES have an adapter. That is going to be a sweet setup! Alan has more info on the adapter and will chime in.
Old 04-16-2019, 09:03 AM
  #1104
vt951
vt951's Avatar
Just checked with iAbed. His adapter will be machined from stainless and should cost under $400.
Old 04-16-2019, 09:07 AM
  #1105
senior_squishy
senior_squishy's Avatar
Wait wasn't that for the RS3 manifold? Or are they the same as the TT RS headers 🤔
Old 04-16-2019, 09:16 AM
  #1106
vt951
vt951's Avatar
same thing I think
Old 04-16-2019, 09:27 AM
  #1107
hinton
hinton's Avatar
All, we now have an option for both solid and rubber pucks on the engine mounts. The rubber mounts are extremely stiff and should be a great base option. However, we wanted to have solid aluminum pucks for anyone that is going to get crazy with power or is concerned about a bonded rubber puck. Solid pucks are a $50 adder.
Old 04-16-2019, 02:23 PM
  #1108
Cjar
Cjar's Avatar
Any early concept pictures of it? Looking for how far it moves the turbo. ETA?
Craig
Old 04-16-2019, 02:26 PM
  #1109
Cjar
Cjar's Avatar
same thing I think
I'm assuming iAbed is making the adaptor for the original TTRS/RS3 engine (codes CEP, CZG) not the new aluminum block engine? I haven't lookup up parts for the new engines yet, but the only difference in the original 2.5T engine was whether or not an exhaust temp sensor was used. Same turbo for TTRS/RS3 otherwise.
Craig
Old 04-16-2019, 02:43 PM
  #1110
Dash01
Dash01's Avatar
Suppose one wanted to "make do" with only, say, 300 HP on an O7K engine swap: Which of the various 07K engines from VW or Audi would entail the least work and expense and most reliability?
Quick Reply: VW/Audi 07K (2.5L 20V I5) Swap Thread
