VW/Audi 07K (2.5L 20V I5) Swap Thread
#781
https://www.mcmaster.com/stainless-s...-with-openings
#782
Wonder if the OE 07k valve cover gasket will work? p/n 07K103483B
On all of the newer TSI engines Audi/VW no longer use valve cover gaskets, they use a green anaerobic sealant, p/n D154103A1. I believe that's what Iroz has used on all of their engines with billet VC's. It's totally still removable, but it is expensive so it's not something you want to make a habit out of.
Issam should be able to recommend some stainless steel wool, he has used that in some block breathers he designed for older I5's.
#783
For breathers: the heavy duty diesels we work on just use a steel wire pack. It's heavier gauge than steel wool, but nothing special. For reference, the area is 2" x 4" and this is enough for a 14 liter diesel.
Craig
Craig
#784
I know the 07k uses a returnless fuel system , like the LS engines do . I am pretty sure these are set at about 50psi at the rail and it does not change . I would say using the calculator you posted , 8 of the stock 07k injectors would feed another little project I am working on . Guess I need to get some graduated test tubes and start working on an injector test bench .
Is there any reason why the stock gasket wouldn't work? is the footprint of the new valve cover now the same as the OEM vc? and if it isn't, could we not modify the stock gasket with like an exacto knife?
#785
The first thing that came to mind for me was stainless column packing used in smaller stills for reflux before hitting the condenser:
https://milehidistilling.com/product...cking-1-pound/
It looks similar to the pack Cjar posted above so it should hold up well.
#786
Went and had some fun at Alan’s this morning. Took a ton of product pictures and started putting together instructions. Even filmed a video, which we should be able to drop this coming Friday.
#791
I spent about 4 hours yesterday in front of a blast cabinet that looks like the one in the background . Gotta get the 928 up and running so I can take the 944 apart ,,,,, right ?
#792
As Mike and I were going through the installation process step by step, we found some hardware that was not quite the right length, and some missing for the PS pump mount and valve cover. So, I have it all on order and should arrive on Tuesday.
In regards to the breather box, it is a -10 AN port (o-ring boss fitting). I'm not sure what everyone will want to use (90 degree fitting or banjo?) so I'm not including that fitting with these kits.
Thank you Mike for the awesome camera skills. It was really cool watching the process of taking professional quality product photos. Now we just need to get the boost brothers store up and working!
#793
Hey I think i found found something similar here: https://www.mcmaster.com/7361t13
I ordered a couple packs that will arrive tomorrow.
