Tial Wastegate adapters
#62
Sure no problem!
#63
Few sets left.
#65
Freedom Enthusiast
The 46 has completely different mounting patterns. It mounts right up to the stock crossover pipe with no modifications or adapter plates needed. It does not match up with the dump pipe into the exhaust. The dump pipe can be modified to fit, or a completely custom one can be made or you can go wild and just dump to atmosphere.
#68
Hahaha.... I had to do this for the 30mm canon on the Apache longbow helicopter when I was in the ARMY. We all had to take a class for it. Among other safety wired items(that's classified, I would have to kill you if I told you, I think, never debriefed). That is a bit overkill for the wastegate. I like it a lot!!!
#69
on my LR wategate I have to saftywire every bolt, otherwise they shake loose. have used every form of high end washer available, but need a mechanical lock. will be saftywiring my tial
#70
Originally Posted by ;12608252
If you have a set available I'll take it
#74
#75
Anyone have a pic installed? Looks like the tial wg installs differently? Instead of the bottom of the wg attaching to the exhaust the side of the wg does? In figuring this because one of the adapter plates is notched for the wg housing and is also flanged for the exhaust pipe.
Also anyone support the wg in any way? Seems heavy to be resting on the crossover pipe only
