Carlsbergas (Vytenis) 951S
#76
nope.. but this one has 270k miles. before this one I had to work with a towncar wich had a 540k miles, was still going strong just needed 1quart of oil every week D
#78
my cars, guess which one I like to drive :d
Attachment 797762
Attachment 797762
#79
reno808 lee101315 what would be the signs od broken torsion bar while having this setup?
Attachment 797796
spring info 0700.225.5350
Attachment 797796
LOL Lart....
#82
today ill start preping car for new mount installation. ill use a clarks garage diy for changing mounts. now the tricky part will be carrier mount replacement.
I didnt look closely enough. but I think ill have to get ac compressor out of the way and remove PS rack, will it make enough space for me to work there? or will I have to take of some parts of exhaust too?
#83
#84
maybe I should remove the turbo, just to take a look and few measurments so I could identify it. that way I would probably get access to caroer mount from the top too
#85
Maybe you can get by without removing the turbo if you sneak the mount out from underneath... it wouldnt hurt!
#86
if ill remove the turbo ill have to wait till tuesday when my gaskets and o rings will arive from LR
just checked diy on turbocharger removal on clarks garage, looks pretty much straight foward.
#89
Was just flying thru disassemble, got stuck a bit longer than expected with heat shield, but removed it. Been having fun trying to get to few bolts on crossover pipe, they are tricky mother****ers!! Going to continue my battle with them tomorrow, its 4:30am. Time for me to get some sleep
#90
Basic Sponsor
if you need a hoist maybe Reno can lend you his
https://rennlist.com/forums/944-turb...ml#post5294078
