Carlsbergas (Vytenis) 951S
Old 12-14-2014, 11:19 AM
  #526
jmj951
jmj951's Avatar
Originally Posted by Carlsbergas
Radiator hoses. Silicone or rubber?
Since you can get an entire set of silicone hoses from Lindsey, you might as well go with a superior part. Only downside is that since it's not as flexible, it can be much more difficult to install. I really didn't enjoy installing the silicone hose set.
Old 12-14-2014, 02:01 PM
  #527
Carlsbergas
Carlsbergas's Avatar
Thanks for the info!
Old 12-19-2014, 12:48 PM
  #528
Carlsbergas
Yesterday while driving with my brother we noticed that while pushing the car at wot there are somekind of vibrations, doesnt happen while cruising, just flat out on any gear. Any suggestions? Can it be related to bad coilovers or axles? Or is it torque tube or clutch?
Old 12-20-2014, 05:41 AM
  #529
jmj951
jmj951's Avatar
I wouldn't suspect the suspension, I would definitely lean toward the clutch. My car does it when the clutch is not warmed up. I can make it vibrate on WOT on short drives, but at the track where I'm pushing it hard for an extended period of time, the clutch will hold better and the vibration goes away quickly.
Did you notice this at all in warmer months, or only in the winter when it's cold?
Old 12-20-2014, 11:46 AM
  #530
Carlsbergas
The vibrations on clutch pedal at higher rpms and at wot been there for a while now.. clutch still feels strong and hooks up as soon as I start releasing the pedal, might have bad bearing maybe
Old 12-20-2014, 12:40 PM
  #531
944Phil
944Phil's Avatar
Does it get worse if you haven't pressed on the clutch for a while? I had an issue with the TO bearing moving off center and vibrating like that and when pushed the clutch in it would reset it for maybe 30 seconds. I only felt the vibration when I pushed the clutch with, but it wasn't a good feeling. I had put the concave ring around the TO bearing in backwards.
Old 12-20-2014, 01:00 PM
  #532
Carlsbergas
If I cruise it doesnt matter at what rmps it doesnt vibrate, as soon as I floor it and change gears it starts to vibrate and stops after like 20seconds of normal driving. But that doesnt explain vibrations coming from the back, I do have kokeln solid trans mount, and my drivers side axle clunks at low speeds atleast I think its the axle im about to change it
Old 12-20-2014, 03:11 PM
  #533
User 52121
User 52121's Avatar
Check all your axle bolts
Old 12-30-2014, 11:25 AM
  #534
Carlsbergas
Started to hoard parts
So far:
2 new cardone axles
Front rotors and pads
Ss braided brake lines front/rear
Retaining springs for parking brake shoes
Timing belt
Balance shaft belt
Fuel filter
Oil filter
Odo gear
Brake flush kit
Thermostat
And run out of car money lol
Still need water pump
Coolant hose kit
Special tools
And other goodies
Old 12-30-2014, 11:47 PM
  #535
ehall
ehall's Avatar
So far:
2 new cardone axles
Timing belt
Balance shaft belt
Fuel filter
Oil filter
Odo gear
Brake flush kit
Thermostat
Coolant hose kit
Special tools
And other goodies
That's how you know when you have become a TRUE 951 guy!
Old 12-31-2014, 10:27 PM
  #536
Carlsbergas
Thanks! I guess my wallet is crying but my heart is in joy knowing that my car is taken care of! Took me a while to understand what means to own a 951!
Old 01-13-2015, 11:27 AM
  #537
Carlsbergas
More car parts!
Old 03-11-2015, 09:19 PM
  #538
Carlsbergas
Just a minor sedback.. lol
Old 03-12-2015, 08:56 AM
  #539
ZX9RCAM
ZX9RCAM's Avatar
Damn, sucks....
Old 03-12-2015, 12:38 PM
  #540
User 52121
User 52121's Avatar
Ouch.
How the hell did that happen?
Something's in the air out here... seen a LOT of accidents the last few days.
Quick Reply: Carlsbergas (Vytenis) 951S
