Another day at the Dyno
I am surprised the SFR headers/crossover pipe flowed well enough to support that kind of performance. I know the set of "Stage II" crap Tim sold me wouldn't have. I am guessing this is a tribute to Chris's ability to tune a car, as I wouldn't be surprised if that was the limitation he had to overcome. Well done, Chris!
Oooh...Harsh...but fair....
Yep, which is why I bought a set, then Tim sent me some cheap $h!t Midas Mufflers would have been embarrassed to claim as their work. Total, very expensive $h!t that doesn't fit properly.
This thread isn't meant to be a bashfest, but to praise Chris on his efforts. Lets turn this back to the original subject.
Pump gas - 93 octane. Its a street car with lots of midrange torque, no need to rev it up. I am sure it could run to 7k if needed, but not worth the wear and tear. To really make use of the upper rpm I would have to change the cam timing a bit - but I think its better to keep the low end.
If you look at the 20 psi boost curve you will see that it was already making 3psi of boost at 3krpm and 7psi by 3.5k.
and good job see the reason for the 'extra' torque on the 12psi run, obviously you know how to read a dyno graph!
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
the turbo is a Tial GTX3582R (.82 A/R)...one of my favorites for 3 liter engines!
The 7psi is a 'fuzzy' number. how you run the dyno session can vary that quite a bit. the test was started at 3k rpm steady speed followed by wide open throttle. If I started it at a lower rpm it would have been a little higher. The acceleration rate (based on the dyno load) also effects the rate the boost builds. the dyno is a Super Flow eddy current dyno, I can program in any load - I shoot for a 'real world' set up to try and duplicate the rate of acceleration that the car would see in normal use.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
OK, since the SFR headers were commented about....there was an interesting problem during the first dyno testing.
during the initial tuning I could not control the boost, it kept creeping up above the setting (using an Turbosmart Eboost2). I checked all connections and it still crept up. Then I swapped the wastegate...still had boost creep. Then I tried no boost controller (running of wastegate spring)...no difference. So I pulled out the wastegate and put in a very low pressure spring...didn't help.
after a couple of days trying everything possible I had to take the car off the dyno and look at other causes.
In the end the problem was two fold - the wastegate pipe came of the header at a 90 degree angle - it really should be more of an obtuse angle - but I have seen this before with Tim's headers and it has not been a problem. It turns out that the wastegate pipe had a 1/8" lip inside the main crossover pipe. With the exhaust velocity inside the cross over pipe this was enough to kill the flow in the wastegate pipe. In fact the boost would have still been uncontrolled if the wastegate was removed and the pipe left open!
I believe that this would not have shown up in 95% of installations, this particular engine is working so efficiently that even the smallest details matter.
By more of an obtuse angle than 90^ do you mean 'away' from the direction of flow or towards? Assume 'away' but then is this getting into reversion or backpressure as such?
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I still feel that a driver that learned without ABS can drive better than a driver that relies on ABS. Some people believe that the proper way to drive an ABS track car is to just push the brake pedal down as hard as possible and allow the ABS to sort it out, I believe that this makes for an uneven transition to trail braking.
BTW - the car owner is already wondering about going to a bigger A/R on the hot side - I am against it for a street car. On this car I think we are making enough power that adding more will start to create a problem with block stability.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
describing it is a problem since you can measure the angle from either side! You want the pipe to be at less than 90 degrees from the turbo side of the crossover.
I believe that lockup is as much to do with brake boosters and certain pad types as ones right/left foot.
Abs is the lazy man's way but it's also going to be faster the majority of times.
