Silicone Coupler Questions
Working on fabricating IC pipes and have a couple questions:
The stock intercooler inlet/outlet are about 2.40" in diameter, will a 2.5" silicone coupler work here?
The stock throttle body is about 2.85" in diameter, will a 3" silicone coupler work here?
TIA
TIA
Yes and Yes or a 2.75 coupler will stretch as well... also check this site out http://siliconeintakes.com/ that's where I get my couplers, fast shipping and good prices and quality.
Yep, I had found Silicone Intakes and am buying most of my stuff from them.
Also found this aluminum 3" to 2.5" reducer to use at the throttle body on Ebay:
I prefer to stretch a smaller size coupler over the pipe. It tends to seal better that squishing a large coupler onto a smaller pipe size. I used 2.25" couplers on the intercooler inlet/outlet and a 2.75" coupler on the throttle body.
LR IC Pipes - $380
Self Fabricated IC Pipes - $70
Thanks Dave! Exactly the input I needed!
I agree here, I used a 2.25-2.5 inch coupler on the intercooler inlet and a 2.75-2.5 coupler joining the compressor outlet to the pipe. Tighter is better and silicone is stretchy.
Location: Bangkok, Thailand, Milpitas, CA & Weeki Wachee, FL
1 Post
Shawn:
Always check with Lart on stuff like this. I got a nice set from Lart, Kohlken's, polished, silicone couplings, T-bolt clamps. $150 delivered.
When you get over 20 psi highly recommend good clamps, spring loaded T-bolt should be used on compressor outlet.
http://www.turbohoses.com/Clamp.htm
Professional Hoon
IMO you don't need T-Bolt clamps if you've got beads on the pipes. If you've got good thick hose clamps, they wont come off.
The only time they'll come off if your couplers are rubbish and dont grip or you have no beads.
1 Post
I remove all normal hose clamps necessary or not. I don't like the look of them. Just look cheap to me and don't belong on a Porsche, even if they were OEM. Then again I am **** like that. I agree about the bead, but have seen many blow off with a bead and cheap clamps, not just Porsches either. Many Ricers at the drag strip have this happen. Some people also make the mistake of using a small amount of oil or grease to make undersize couplers slide on easier. Another big No No!
Professional Hoon
No, no grease. I've heard of people doing that. But that's asking for trouble.
The clamps I got with my SFR pipes are really good. nice, thick and can get done up tight.
Many people dont know this but you tighten them up with an 8mm socket not a screwdriver. you get more torque with a socket.
