Another "Won't Start" Thread
Old 06-09-2013, 03:56 AM
Kyle Donley
Kyle Donley's Avatar
Injectors fire, but still no spark
Cleaned grounds for good measure no real corrosion
Tested coil per Clark's Garage - seems okay
Tested speed and reference sensor resistance - both good
Bypassed KLR terminal 9-16, still nothing
Old 06-09-2013, 03:57 AM
Paulyy
Professional Hoon
Paulyy's Avatar
did you check if theres a pulse at the coil?
Old 06-09-2013, 04:02 AM
Kyle Donley
Checked no pulse on the negative side of coil while cranking.
Old 06-09-2013, 04:14 AM
Paulyy
Professional Hoon
Paulyy's Avatar
DME
Old 06-09-2013, 01:35 PM
Tom M'Guinn
Tom M'Guinn's Avatar
Well sounds like testing the DME is the logical next step. The ignition driver on the DME may be burned out. In the thread below, see info about how to replace the dead transistor if you are comfortable working on electronics like that.
https://rennlist.com/forums/944-turb...e-too-hot.html
Old 06-09-2013, 04:27 PM
Kyle Donley
Thank you, thank you, thank you, thank you!
It started!
I've had the DME open sitting on the carpet this whole time, inspected solder joints, resoldered some etc.
After reading the other thread you linked I unfolded the DME and touched up the connections to the transistor with the soldering iron. Plugged the DME back in and she fired right up!
I can't thank Tom and Pauly enough. I've been pulling my hair out trying to track the problem down.
THE POWER OF RENNLIST!
Old 06-09-2013, 06:33 PM
Tom M'Guinn
Great news! Sounds like your original diagnosis was spot on, but very happy to hear you were able to narrow it down to the offending DME component so you could fix it yourself and save the $500 and week of down time. It's a great feeling when you find and fix something like that -- congrats! Pics for posterity would be good if you took any...
Old 06-10-2013, 12:03 AM
Paulyy
Professional Hoon
Paulyy's Avatar
I know how you feel. I went though that a few weeks ago. Ended up being injector harness
Old 06-10-2013, 01:15 AM
Kyle Donley
I didn't take any pics of the work or offending electronics. But here are a couple of a now running filthy Turbo!
Old 06-14-2013, 11:43 PM
Kyle Donley
Took the car out for a drive today and it came back on a flatbed.
Replacement DME has been ordered from ECU Doctors.
Old 06-15-2013, 01:45 AM
Paulyy
Professional Hoon
Paulyy's Avatar
how much you paying for it, is it rebuilt? go get yours fixed too and get some money back
Old 06-15-2013, 03:20 PM
Kyle Donley
$300 for a reconditioned unit, $400 core.
They will also repair and return your unit for $350.
Both carry a 5 yr warranty.
Quick Reply: Another "Won't Start" Thread
