My porsche 944 S2 16 valve turbo project
Old 10-07-2016, 05:29 AM
  #316
nick_968
User
nick_968's Avatar
Originally Posted by 333pg333 View Post
Tim comes from the Clouds!
KW's are the best riding shocks I've used so far. Cons are that there is a question over some of the build quality on external components. The plates for their top mount camber plates is pretty flimsy. Better off with Racers Edge top mounts and not just for the build quality. The RE's give you greater droop and helped in curing some push understeer I encountered some years ago. There's also a U shaped surround around the adj eccentric bolt. This needed to be welded onto shock body as it worked loose via the apparent tack welds it came with. Apart from that I thought there were great for a street/track car.
Tim good to see you back on the board. I have also had good experience with the KW's on the road but mine did not age so well, I had some squeaking from the shocks and although the body of the shock was good the springs corroded after a few years. Not sure the AST one ways I replaced them with will wear so well either but I wanted to try a monotube shock out. The spring rate my AST's came with is a little harsh for the road so I am considering dropping it down by 40lb front and rear. They do handle the power very well though and the adjustability does let them go quite a bit softer to compensate for the spring rate. Unfortuntely I have not had enough time with the car this summer to give a proper comparison but I would say to be careful going too high with the spring rate on the KW clubsport as these are more track focused although depends what your intention is for the car.
nick_968 is offline
Old 10-07-2016, 06:41 AM
  #317
333pg333
333pg333's Avatar
Not sure what rates the Clubsports come with out of the box? If it's for mostly street driving then perhaps the V3's would suffice. Not sure of your road quality there guys? I ran the more stiffly sprung race version and they were fine on the street in my opinion but it's all subjective. Nobody that ever went in my car back then complained of the harsh ride though.
333pg333 is offline
Old 10-07-2016, 06:53 AM
  #318
nick_968
User
nick_968's Avatar
I think it is your choice with the Clubsports but there may be a default option possibly around 400lbs/ 80nm up front?
On the road I think it is important to have that compliancy to soak up bumps and ride over them as opposed to bouncing over them if that makes sense as it makes for more fluid progress. Always hard to get that road track compromise for an occasional track day car.
Road quality varies but on country roads you need a softer setup to get the best out of the car. Depends on use and where you live I guess.
I think the V3 spring rates are probably the sweet spot for the road although Tim is running a lot of power which may effect spring rate choice.
nick_968 is offline
Old 10-07-2016, 07:12 AM
  #319
Jherriott
Jherriott's Avatar
Originally Posted by turbotim3 View Post
One or two pic's of my own
Wait... Are those back-up sensors integrated into the rear bumper?
Jase.
Jherriott is offline
Old 10-07-2016, 04:44 PM
  #320
turbotim3
User
Jase.
Yes, your right pdc sensor set up fitted by the previous owner
turbotim3 is offline
Old 10-08-2016, 09:05 AM
  #321
333pg333
333pg333's Avatar
I'd say to this point Nick that not all Apples are Apples. As in, spring rates are one thing but shock valving is another. So you might have someone with say Bilstein Escort Cup suspension and 400lb spring and someone else with KWs and 600lb springs. I know which I've found clearly more compliant and 'agile' over uneven surfaces. I know you like KWs having ridden with you in the 993 'Company car' all those years ago. I still remember being impressed with the ride quality and your driving ability. :-)
333pg333 is offline
Old 10-08-2016, 03:40 PM
  #322
nick_968
User
nick_968's Avatar
I agree Pat but my understanding is that if you order say a set of KW Clubsports they will set the valving according to your spring choice as the two have to be matched. I always thought there is a range that you can change the springs around a given valving but outside of that the shock will not effectively control the spring possibly +/- 20nm. If you go outside of that range you may need to have the valving on the shock changed to get the best out of it. The KW's are a twin tube shock which also helps with the ride quality.
With V3's the spring rate is not a choice so you get the matched setup out of the box. The 993 with the V3 kit was pretty much the perfect compromise for road and track although when pushed hard it did start to show its limits but fine for a fun car. I am not sure if it was my ability or just the perfect balance of that car the way we had it setup. I do miss it a lot. Hopefully next time you are in the UK I will be able to take you for a spin in the 968t
nick_968 is offline
Old 10-08-2016, 05:04 PM
  #323
333pg333
333pg333's Avatar
I'm sure you're right on the springs Nick. We probably moved well out of the range in the last iteration of spring that I wound up with. Not sure if we did any damage to the valving by going up to 140/160 in the last iteration of these? That was pretty firm on the street though.
Would be great to catch up again. :-)
333pg333 is offline
Old 11-21-2017, 10:41 PM
  #324
geno
User
geno's Avatar
Sorry to bump an old thread, but was it ever confirmed that Tim did NOT use the factory cams? It was once mentioned that he may have had them reprofiled, but I've read through this all twice and never saw comments beyond that.
geno is offline
Quick Reply: My porsche 944 S2 16 valve turbo project
Contact Us - About Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
