Need tall gear set .73 for 944 trans
Old 03-24-2013, 12:57 AM
Alan 91 C2
Alan 91 C2's Avatar
Default Need tall gear set .73 for 944 trans
I want to swap out my .83 gear set. Anyone have the .73 set?
Old 03-29-2013, 12:30 PM
Alan 91 C2
Alan 91 C2's Avatar
Default Bump
Anyone have the tall gear set to trade for short set?
Old 03-29-2013, 01:09 PM
9turbo51
9turbo51's Avatar
I have a 5th gear set from an S2 transmission (.73). I have no need for a short set.
I have zero idea what it is worth, any ideas?
Old 03-29-2013, 03:10 PM
Oddjob
Oddjob's Avatar
FYI - S2 5th is .778.
Old 03-29-2013, 05:43 PM
docwyte
docwyte's Avatar
Contact the 944 Spec guys, they have loads of the tall 5th gears laying around. BTW, you shouldn't be offering to trade gear sets, your short gear 5th is worth $4-500, the tall 5th is worth no more than $50-75.
Old 03-29-2013, 06:51 PM
Alan 91 C2
Alan 91 C2's Avatar
Thanks for the replies.
Old 03-30-2013, 10:26 AM
9turbo51
9turbo51's Avatar
Thanks for correction.
Sorry, didn't have chart at work with me, going off memory, or lack there of!
Old 03-30-2013, 11:08 AM
Oddjob
Oddjob's Avatar
There was a post by Kevin Gross in the recent trans thread on the N/A forum about interchangeability (lack of) of 5th gear sets between Turbo and N/A boxes.
Alan, not sure what box you have, but based on what Kevin stated, you might to check into that and get clarification before putting an N/A 0.730 gearset into a Turbo box (if that is what you are looking to do). The .778 S2 gearset is for sure compatible w/ a Turbo transmission.
Old 04-01-2013, 03:59 PM
docwyte
docwyte's Avatar
I have a 0.73 NA 5th gear set in my AOR. It fits fine.
Old 04-01-2013, 05:10 PM
Oddjob
Oddjob's Avatar
According to Kevin's post, its an oiling problem due to different oil supply design between the turbo type and the N/A transmissions, not a physical/dimensional fitment problem.
The issue he brings up may just be a problem when installing a Turbo 5th gearset in an N/A transmission, and may not be a problem when installing an N/A gearset in a Turbo trans. Up to you if you want to look into it further.
Old 04-02-2013, 07:10 PM
Chris@Fabspeed
Former Vendor
Chris@Fabspeed's Avatar
I have a good .73 gearset I will never use, pm if you still need it
Old 01-10-2019, 10:38 AM
xsocaltrashx
xsocaltrashx's Avatar
Also looking for a tall 0.73 gear or even a 0.68 5th gear out of an audi. It's for my 948, Please let me know if anyone has one or knows where I could get one. Thank you!!!!
Old 01-10-2019, 05:52 PM
KevinGross
KevinGross's Avatar
Correct. Not clear from the OP which version of the transmission is being discussed. If it's a transmission as originally delivered in a 944 eight-valve, normally-aspirated car, then the taller 944S2 fifth gear will not work. If it's a transmission as delivered with a 944S, S2, or Turbo, the S2 gear set will work just fine. Good luck!
Old 08-31-2020, 10:19 PM
odurandina
Team Owner
odurandina's Avatar
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
so, once and for all, what is the tallest 5th gear final drive combination for the 944 5 speed box?
is it the 944T box running an S2 5th?
Old 08-31-2020, 11:52 PM
mtnman82
mtnman82's Avatar
Is DFastest still around? I think he went thru this looking to break the 200 barrier?
Quick Reply: Need tall gear set .73 for 944 trans
