Pls advise: how best to spend $5k in 951 repairs?
Great feedback, guys, this all really helps.
As for the engine suggestions from 'Robstah,' all of that stuff should be good. Belt is I think 2-3 yrs old, and all fluids were done in last year or two. Electrical is a bit spotty, I admit. The Vitesse turbo is normally good for 17 lbs of boost, but lately has been only 15. Not sure if the timing settings got accidentally messed up, or what.
Yes, will start w/ brakes & suspension.
But first thing will be check compression, esp the #2 bearing, which I guess my dad says notoriously fails? If it's bad, he says to walk away.
But yes, to address 'rcarpen22,' I kind of think that this car's color combo (Titanium silver on burgundy leather) is the best combo I've ever seen on a 951 (no offense to other combos!), though red on black leather is def sexier. And the fuchs are just classic, although I can't even find good rubber on 16's any more (No Michelin SP's in that size). So yes, hard to let it go. But maybe if one of you kind souls out there convinces me you'd be a proper caretaker for her, I could be open to parting ways...
I was working a job that required me to travel all the time, so I didn't have time to work on my car. The clutch fork actually broke, so the clutch wouldn't engage (even though the clutch itself was ok. I took it to my favorite local shop to have the clutch replaced. While they were in there, they pulled the pan and replaced the rod bearings, put a new pan gasket on, and fixed some electrical gremlins I had. All of that was less than $5000 including the parts. Even if the #2 rod bearing is bad, I stick to my position:-) But if you do sell it, make sure it goes to a good home.
PS, after finally passing safety inspection (for silly stuff) I am now once again using the turbo as my daily driver. These are great cars and very practical if not modded too heavily. FWIW, I took my MAF off and just went back to the stock AFM and airbox. Better gas mileage and drivability for me without too much noticeable loss of power. I'm old though, so I don't drive too crazy on the street anymore.
It's not a daily driver for me, as I work in the city and just take subways (much quicker, easier). I basically use it on weekends to get out of the city, trips to Long Island, upstate NY, VT, and family in Boston & Maine. I'll be driving it all over New England for June, though, and that alone is worth $1-2k for me in enjoyment and saved car rental costs.
Pursuant to what I mentioned earlier, it might be worth trying to find a well-regarded independent mechanic who will let you supply parts now and then. As an example, Porsche axles are around $400 apiece if memory serves. VW equivalents from their van are considerably cheaper, and there's a thread here on Rennlist about which part works.
There are dozens of other examples, and a few excellent aftermarket suppliers, even of maintenance items (engine bay fuel lines, for example).
One other note: if this is to be your only car, or a winter car, I wouldn't recommend it as highly. If not, go for it!
