Turbo clutch on a S2 motor
Should be imo.
Bell housings are not necessarily different. My 85/2 NA had the exact same bellhousing as 952 S I parted.
Probably starter engage gear was bigger in diameter.
The clutch itself should be fine. The 951 has a slightly different fork and bellhousing.
The S2 has 1/2 the flywheel teeth of the NA, not sure about the 951, so check that as well.
Think about electronics too. The S2 uses a different sensor setup for the flywheel. 60-2 toothed wheel on the S2 flywheel and the turbo counts the starter ring teeth and has the reference sensor.
I'm under the impression that, if you want to use a 951 DME and KLR, you have to use the 951 bellhousing and clutch assembly in order to accommodate the speed and reference sensors.
THis. Not sure why everyone is overlooking this. It may be possible to drill and tap 60 holes in the turbo flywheel and install some set screws, but it is most definately note a bolt on. And as stated, the diameters are different, so the flywheel, cluth, and pressure plate are all a set.
