Refresh951's Hybrid Ultra Stroker Build
Old 11-08-2013, 12:48 AM
  #1021
blown 944
blown 944's Avatar
It'll be fine. Your trap will be fairly consistent regardless of launch. You'll be in fourth for half the track so it'll show a solid mph.
I'm expecting you to hit 120 unless you can't keep it from spinning every time.
Old 11-08-2013, 06:20 PM
  #1022
DanaT
DanaT's Avatar
This makes me want to build one these engines..
Old 11-08-2013, 06:28 PM
  #1023
V2Rocket
Rainman
V2Rocket's Avatar
Originally Posted by refresh951
The plan is to go to the Atlanta Dragstrip in Commerce tomorrow night. It is the last open date of the year. With the S2 tranny it looks like I am going to redline in 4th at about 114mph so I may have to shift into 5th.
Raise the limiter to 7000 to get over 120? Shouldn't hurt anything to do it once or twice...
Old 11-09-2013, 02:33 AM
  #1024
refresh951
refresh951's Avatar
Well, made it out to the drag strip tonight. Big thanks to Josh B for coming out to film and hang out Plan was to make a couple passes at 17 psi then a couple passes at 20 psi. I arrived at 6:30 pm and made my first run within 30 minutes. First run, missed 2nd gear and turned a 14.1 time Went straight around and staged, then 3 major accidents happened in a row and I sat in the staging area for over 2 hrs. Was only going to get one more run so decided to go for it. Cut 0.7 sec off my 1/8 mile time but hit the rev limiter and that blew my run.
Overall, great learning experience. First run was pretty nerve racking lol. When I first arrived I parked next to this Viper and talked to the owner and his teenage son a bit. I asked him a bunch of questions about the track, he told me it was only is second time out. He was one of the major accidents, apparently braked to hard and lost control at the end of his run (not sure exactly how) and he slammed his Viper into the wall. He was fine however.
No issues whatsoever with my car or motor, just the driver
Old 11-09-2013, 12:36 PM
  #1025
gruhsy
gruhsy's Avatar
Awesome. Very unique sounding motor/exhaust. I like
Old 11-09-2013, 12:59 PM
  #1026
refresh951
refresh951's Avatar
Thanks Jason! Definitely going back in the Spring to see if I can do better...it is harder than it looks. I have gotten quite a bit of positive feedback about the exhaust note. Kind of funny as I built the exhaust for just over $200 including the OBX muffler for $50 on Ebay.
Old 11-09-2013, 09:00 PM
  #1027
hally
hally's Avatar
Cool
Old 11-10-2013, 06:41 AM
  #1028
333pg333
333pg333's Avatar
Out of curiosity, what was your trap speed Shawn?
Old 11-10-2013, 02:17 PM
  #1029
Tom M'Guinn
Tom M'Guinn's Avatar
Great video. Were you on street tires? Getting these cars to hook up and stay there is a real challenge after a certain level of HP. I remember Special Tool's car spinning most of the way down the track. Somehow, with the speedometer calibrator input, an rpm input, a gear sensor, and a boost solenoid, there's an Arduino project brewing in there somewhere... It could double as a gauge to confirm when the tires are spinning vs when the clutch is slipping...
Old 11-10-2013, 02:45 PM
  #1030
numbskull
numbskull's Avatar
Car sounds great! That was a super short 2nd gear.
Old 11-10-2013, 07:27 PM
  #1031
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
Two runs the entire night..! Too bad, it would have been nice to see what it does on a clean run. Always next year
The car looks amazing, BTW.
Old 11-10-2013, 09:45 PM
  #1032
refresh951
refresh951's Avatar
Originally Posted by hally
Cool
Thanks Hally!
109 mph, 60 foot 2.26
Street/Track Tires. Toyo R1R, 275's. I have a new Arduino Project (see my Head Flow thread)
Thanks! Yes, super short
Thanks Joshua. I absolutely love the Tuner/Logger. Ran 5th injector at the strip then switched to 4 injectors on the drive home with a fuel economy tune.
Old 01-31-2014, 09:31 PM
  #1033
refresh951
refresh951's Avatar
Came up with a what I think is going to be a pretty cool large plenum, short runner intake design. I purchased DIY components from Ross Machine Racing:
http://www.rossmachineracing.com/
The stuff is very nice quality and well designed. The velocity stacks are designed to be inserted in 3 inch diameter holes and also machined on the back side to accept the runner tubing.
Purchased the d shaped plenum, velocity stacks, end caps, and runner material for $280. A buddy is going to come over to Tig weld everything for me for $200 so I should have just a little over $500 in the intake when completed. Hopefully it will be completed in a couple weeks and around the first of March I am planning to dyno with the new intake.
Old 01-31-2014, 09:34 PM
  #1034
Josh B
Josh B's Avatar
Lookin good!
Old 01-31-2014, 09:35 PM
  #1035
NZ951
NZ951's Avatar
Quick question, just to be a ****...
Did you take into account the volume of the pipe post the throttle body pre the plenum in the volume calculations? Did you take into account the runner volume in the volume calculation? And finally, should you...
NZ.
Quick Reply: Refresh951's Hybrid Ultra Stroker Build
