Refresh951's Hybrid Ultra Stroker Build
Old 03-17-2013, 10:12 PM
  #346
refresh951
refresh951's Avatar
It took me the better part of a day to finish the 3" down pipe and modify the exhaust. Everything is done and tacked and I am really happy with the fit. Going to take the down pipe to my friend and have him finish up the welds. I should be just a few day away from first start now.
Old 03-17-2013, 10:29 PM
  #347
refresh951
refresh951's Avatar
Below is the setup for first start. I plan to dyno this setup as a baseline after break-in. Then I will begin making changes to eliminate restrictions and qualifying the changes at the dyno. I will be making my own SS 3" exhaust during break-in this will be the first change after initial dyno:
1) Full 3" exhaust
2) Custom Intake with 928 TB (thanks for the TB David Floyd)
3) Larger Intercooler
4) FRF Headers
Old 03-17-2013, 10:34 PM
  #348
refresh951
refresh951's Avatar
Originally Posted by blown 944
Nice work once again Shawn.
Thanks!
DME.... Sworn to silence
lol
Old 03-17-2013, 11:30 PM
  #349
blown 944
blown 944's Avatar
Very cool.
Shoot me an address to send the intake. Iirc, you may need to re-angle the TB flange.
Nice drawing!!!
Old 03-17-2013, 11:39 PM
  #350
TonyG
Rennlist Junkie Forever
TonyG's Avatar
refresh951
Next time you make a wiring harness you should consider throwing away the DME/KLR and using a GM LSx computer.
They are dirt cheap, will run the 4 cylinder in any mode of injection, full speed density or without a MAF, and have pretty much all the mapping capabilities of a Motec plus traction control, and a bunch of other cool things.
Used they go for about $80 on ebay.
And there are a million people that can tune them and the software to tune them is cheap.
And these computers blow away basic stand alone systems (eg., TEC3r).
It's a big step up in engine management for peanuts.
Did I mention that you can get them for $80 on ebay?
I wish I knew about these when I was playing with the turbo motors.
Food for thought.
TonyG
Old 03-18-2013, 12:00 AM
  #351
Josh B
Josh B's Avatar
Old 03-18-2013, 12:04 AM
  #352
refresh951
refresh951's Avatar
Originally Posted by Josh B
Man, the 968 looks good!
Old 03-18-2013, 12:15 AM
  #353
Tom M'Guinn
Tom M'Guinn's Avatar
Originally Posted by TonyG
refresh951
Food for thought.
TonyG
Have you used on a 951 motor? Do you know if that box can handle all the stock sensor and triggers? Got to like the idea of a million users and endless aftermarket support....
Edit: sorry --didn't meant to hi-jack. Great build. Tony -- PM welcome...
Old 03-18-2013, 12:31 AM
  #354
refresh951
refresh951's Avatar
refresh951
Food for thought.
TonyG
Thanks Tony. Sounds interesting. I will have a look at it.
I guess you did not have Rogue's stuff when you were doing turbo motors. Very reasonable pricing and exceptional products. Most importantly, when you have Rogue's products you get access to his tuning knowledge which is second to none IMO.
Old 03-18-2013, 12:42 AM
  #355
gruhsy
gruhsy's Avatar
Nice drawing Shawn
Old 03-18-2013, 12:51 AM
  #356
refresh951
refresh951's Avatar
Nice drawing!!!
Originally Posted by gruhsy
Nice drawing Shawn
Thanks. I wanted a drawing where I could see the overall system flow . It is really a visual aid to keep me focused on minimizing flow restrictions.
Old 03-18-2013, 02:00 AM
  #357
michaelmount123
michaelmount123's Avatar
Shawn,
Re your drawing/test plan:
- Would you consider starting with the stock cam and making the swap to the NA cam your first change? I suspect a lot of folks will be interested in the back to back result.
- There's a 5th 80# injector prior to your TB. I presume it's inactive until boost comes up. How are you controlling it?
- Your boost controller will be seeing higher boost than that in your plenum due to the reference location. Are you logging/monitoring boost from the plenum so that indicated boost is close to what the engine is seeing?
Thanks for the info,
MM
PS: Looking forward to the results!
Old 03-18-2013, 02:01 AM
  #358
blown 944
blown 944's Avatar
Michael, I a currently using a fifth injector. It works at all times. Josh has programed my chip for it. Works flawlessly.
Old 03-18-2013, 02:03 AM
  #359
alxdgr8
alxdgr8's Avatar
Why a 5th injector and not just larger primary injectors?
  #360
michaelmount123
Default GM ECU
refresh951
Food for thought.
TonyG
Food for thought??.... this is PROFOUND! I'm not familiar with the GM LS ECU but I'm already looking into it. Thank you Tony!
Quick Reply: Refresh951's Hybrid Ultra Stroker Build
