Refresh951's Hybrid Ultra Stroker Build
#196
Very interesting article, thanks.
What is not mentioned is that increasing CR should help with transient response when varying load by opening the throttle. The curves posted all seems to be at WOT, and I suppose we would need 3D tables with TPS (or VE) as the 3rd dimension against RPM and Power to really get a picture of how CR and boost balance eachother.
#197
Typical Crank Runout: 0.04-0.06 mm (0.0016"-0.0024")
Max Crank Runout: 0.08 mm max (0.0031")
0.003" does seem high especially considering main bearing oil clearance is spec'd at 0.0007"-0.0038" for new bearings. I guess this is where crank flexibility factors in. It is also easy to see why you would want a much tighter spec on a high performance engine.
#198
The problem with using that article with these engines is the lack of four extra cylinders. V8 guys can get away with it while 4 cylinders will struggle. There were noticeable disadvantages towards decreasing CR below 9:1CR on the BMW M50 based engines when we were playing with such data, and those engines have an extra 2 cylinders over the Porsche 4, albeit both were close to the same displacement.
What should also be part of the discussion is a better engine management system. The Bosch stuff is okay at best and having better management will help with power goals as well as longevity. When the BMW scene finally broke into the OBDII ECUs (and figuring out the difference between Siemens and Bosch ECUs was a pain in itself), we were able to find a lot more reliable power right off the bat with minimal tuning.
#199
Small Business Partner
Regarding CR.
For ultimate power, peak cylinder pressure must be kept within reason. If this means sacrificing some efficiency and low-end power, then that is the choice which the owner/builder is faced with.
That said, the added stroke & displacement more then makes up for lower compression (compared to a higher CR, smaller displacement engine). We've seen this on back-to-back dynos of a 2.8L stroker with low CR vs a 2.5L with higher CR.
#200
The best thing about computers is that we can rewrite software, change strategies and algorithms, and generally improve upon the original code (not to mention fix errors in the factory software...).
The factory DME utilizes some hardware brute-force to compensate for the limited computing power available.
For instance, new ECUs, which utilize a 24 tooth, or 36-1 trigger wheel (or similar), must have a predictive (possibly kalman-filter type) algorithm to guess (predict) engine crank-angle at any given time. This takes processing time, and if done in floating-point, it can take quite a bit of processing power. The DME, however, utilizes a very high tooth-count (132 for the 951). The hardware then has narrowed the crank-angle down to ~2.73° window of accuracy without needing any computing power. The microcontroller then only has to run a timer to get to the correct angle(time). This approach is much simpler than the approach used by new ECUs. And allows for quite accurate ignition/injection timing without needing much processing power.
The main limitations I see on the factory DME hardware:
Age (component failure).
The need for the cap&rotor.
Batch-fire injection.
Limited IO (input output).
Lack of engine knock knowledge (only the KLR knows knock).
Lack of non-volatile memory (for fuel/octane trims).
That said, really non of those are deal-breakers, nor do any contribute to a significant reduction in hp/tq potential. In-fact, I would be happy to put up my full Tuning solution against XYZ setup for a dyno session. I seriously doubt there would be any real power difference between the two.
Finally, you are correct, I definitely know the limitations of the factory DME - and I am working to correct them
#201
I would be happy to bet you that a low CR 2.8 can make more power without losing a HG than a high CR 2.8...
#202
I suppose many people may prefer a crisp and responsive engine over a more powerful but slower responsive engine.
#204
2.85L Stroker Dyno (compared to my 2.5L K26/6)
#205
Wow, amazing project, I want to build one!
I have now read both this and the blown944 thread and am serious about having a go at building one of these, but not being on your side of the Atlantic, I am at a bit of a loss to a couple of things.
You mention that they are Mitsubishi Eagle con rods, but is there a specific Mitsubishi Eagle engine code that the rods were originally designed for? I expect you are using an aftermarket rod, such as a Carrillo, but can you narrow down some specifics of what engine these are used in?
You also mention Chevy pistons, again, what are the specifics?
Or is this a commercial thread and this info is a commercial secret?
#206
What would be considered responsive? My car, even at this high elevation will just shred the tires at the push of the throttle. IMHO, with the added stroke, Shawn's car will be borderline dangerous on the street. When you have 300# ft of tq at 3000 rpms and 500 shortly after it would seem to me that it is plenty.
@Rennbod, all the info is there. To build one of these you should be able to dis cipher the pats code. If we just throw out all the part numbers and say bolt it together there may be a few catastrophes. Read a few times through and you can figure it all out easy enough.
#207
Awesome post by mclarenno9 in Paulyy's build thread about fab work to install a GT Turbo:
https://rennlist.com/forums/9975192-post397.html
I think I am going to start a separate thread and detail my approach for installing the GT35 including adapters, oil, water, and fab.
#209
#210
