Refresh951's Hybrid Ultra Stroker Build - Page 121 - Rennlist - Porsche Discussion Forums
Old 04-06-2018, 05:55 AM
  #1801
Voith
Voith's Avatar
That has to be the luckiest outcome for failure of this proportion. Hope you make it even better this time.
Voith is offline
Old 04-06-2018, 06:01 AM
  #1802
blade7
User
blade7's Avatar
Years ago I knew a guy that worked at a successful race engine shop that mainly did 4 cylinder engines. They weren't keen on grinding cranks 1st undersize, and usually advised a new crank budget permitting. OK these stroker engines aren't revving to 8k + and probably only spend seconds over 6k, but grinding that much off and then the force required to cold straighten isn't as good as an option as an original 3.0 crank IMO.
blade7 is offline
Old 04-06-2018, 12:31 PM
  #1803
V2Rocket
Rainman
V2Rocket's Avatar
^^ crank cold-straightening machines are serious business
V2Rocket is online now
Old 04-06-2018, 01:30 PM
  #1804
Humboldtgrin
Humboldtgrin's Avatar
There is a shop in Redding California that rebuilds harmonic dampeners. I believe the cost is around $250. It's pricey but so is everything else on a built 951. IMO it's worth it. http://damperdoctor.com/index.php?ro...mation/contact
Humboldtgrin is offline
Old 04-07-2018, 06:33 PM
  #1805
refresh951
Moderator
refresh951's Avatar
Originally Posted by Tom M'Guinn View Post
If you get a new motor in by June, after I've been sitting on my next-gen motor parts for way too long, I might actually be shamed into action...
If all parts come in as expected it will be done
Originally Posted by 951and944S View Post
Out of curiosity, do you run a non spring damped clutch disc..?
And solid engine mounts..?
On track, short of natural backlash in CVs and transmission gearing, only the length of the long input between the clutch spline and the transmission input shaft coupler absorb torsional forces through the drivetrain when you remove the spring center from the disc and the isolator (rubber mounts) that both absorb torsional forces when you hop the rear tires on an errant or missed rev matched downshift with high grip tires.
BTW - re your video, it's hard to do with traffic, but in a car with your power, after out lap, try making some laps in 5th gear only...., never downshift.
This will teach you momentum faster than anything else.T
Spec hybrid clutch, does have springs, LR semi Solid mounts. This is definitely not a torsional failure.
Thanks for the input on my driving. I will give that a try. I have improved quite a bit since any posted videos
Originally Posted by V2Rocket View Post
looking at the metal grain patterns in that photo that looks like a crack->snap caused by crank whip rather than torsional stress.
probably could've used a revised (heavier?) harmonic damper along with the larger radiuses as mentioned.
if it were torsional failure...easiest to picture a splined driveshaft twisted from mega torque input, the metal twists on itself as if it were a a towel being wringed out, if smaller scale.
I think this is just simply a load failure. I do not believe the harmonic balancer played any major role.
God helped me on this one
Interesting. Thanks for the link.
refresh951 is offline
Old 04-07-2018, 06:35 PM
  #1806
refresh951
Moderator
refresh951's Avatar
Another consideration - When you take the crank out to maximum stroke, you really cannot optimize the fillet radius. The more I look at the 94.7mm stroke, the more I think it is better to back off a bit. This pics shows what could have been if there was enough material. Rebuild will be 92 mm stroke with optimized fillets and nitriding.
Old 04-08-2018, 11:37 AM
  #1807
V2Rocket
Rainman
V2Rocket's Avatar
2? years ago i was gauging interest for having custom billet cranks made, i think Molnar was OK with 94mm (will double check), something around $1500/pc with 5 pc minimum.
i think he wanted a larger rod pin though.
surely the necessary fillets could be built-in at that point.
Old 04-17-2018, 06:10 PM
  #1808
refresh951
Moderator
refresh951's Avatar
Reusing my block, had to overbore the sleeves 0.010" out to 4.040". Quite a bit of wear in the bores, on the order of 0.003" to 0.004". The rod ratio on the 95 mm stroke is 1.58 and it is a factor in terms of wear. Something to consider as you go higher in stroke. Got about 10K miles and a lot of track events. Rebuild is coming along, just need my 92 mm crank and then it can go back together. Hopefully have the crank in 3 weeks.
Old 04-17-2018, 11:51 PM
  #1809
URG8RB8
Super User
URG8RB8's Avatar
Location: Bangkok, Thailand, Milpitas, CA & Weeki Wachee, FL
I doubt many if any besides Emanuel and I would be interested but I will have a quote in a few days from Marine Crankshaft on a full Billet Hybrid Stroker crank at 94mm. Their work is phenomenal even by my standards.
URG8RB8 is offline
Old 04-18-2018, 05:20 AM
  #1810
V2Rocket
Rainman
V2Rocket's Avatar
Old 04-18-2018, 09:57 PM
  #1811
URG8RB8
Super User
URG8RB8's Avatar
Slightly better than Molnar. I too looked into that. There is a reason they are so cheap.
URG8RB8 is offline
Old 04-18-2018, 10:26 PM
  #1812
951and944S
Super User
951and944S's Avatar
And the reason being...?
Are you referring to the pass through at the rod journals..?
A lot of late cranks have this feature.
T
951and944S is offline
Old 04-18-2018, 11:42 PM
  #1813
V2Rocket
Rainman
V2Rocket's Avatar
price =/= quality.
hope your cranks don't come from your cam gear guy.
molnar billets are mfrd in China and then finish machined to spec in USA just like pretty much any other brand of cranks/rods, with few exceptions.
Old 04-19-2018, 02:27 AM
  #1814
Humboldtgrin
The exception would be Thor?
Old 04-19-2018, 05:18 AM
  #1815
Voith
Voith's Avatar
Let me see if I get this right.. Crank breaks in two pieces trough the journal and solution to that is crank with big holes trough journals. Hmmm.
Voith is offline
Quick Reply: Refresh951's Hybrid Ultra Stroker Build
Contact Us About Us Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
