Official V8 Registry.
#136
I couldn't do the pedal system due to my cage, moving the seat back to allow its use put my helmet under the roll bar and I didn't like that.
#138
I made a floor plate of 3/8" thick aluminum that also bolts into the outside door sill. It's solid.
The pedals are about 4" further back from the stock ones.
I extended the steering column with a quick release and added an extension to the shift lever. I was able to move the sear rearward and downward giving me good headroom from the cage. I'm getting away with all of this as I'm 5' 8".
Rich
Rich
#140
Thanks Man. It was a lot of work, probably the hardest part of my conversion. Good luck with yours.
By the way, this is where I got the material. It's a 12x12" plate and a 6" angle.
http://www.onlinemetals.com/merchant...=76&top_cat=60
http://www.onlinemetals.com/merchant...=62&top_cat=60
Cheers,
Rich
Cheers,
Rich
#141
Yeah, this is the part that I'm not excited about. Thanks for the links!
The only other thing that's stumping me right now is how to adapt the old Porsche high pressure fuel line to the Corvette fuel filter/regulator. My Porsche line has a rip in it, so I need to cut it and adapt it somehow.
#142
Rennlist Junkie Forever
That's what you want.
TonyG
#143
Otherwise, lot's of info and part numbers on 944hybrids site for setting up the corvette regulator/filter.
#144
Which uses two of the GM quick disconnects as mentioned above.
TonyG
#145
Yes, the early vette rail has the return but most don't. I believe that Tim was planning on putting the C5 regulator/pressure combo and not returning from the rail (pic below). I have had trouble with those combos, the last one I installed provided 70 psi to the rail instead of 60. I dumped that system and added a return at the rail system.
#146
Anyway, I had real good luck with the 98 Vette fuel rail with its built in fuel pressure regulator. That setup made the installation super simple.
The only reason I'm not using it now is that it wouldn't clear the FAST intake.
My new setup Y's the fuel into the fuel rail, and Y's in back to the regulator (Parallel plumbed).
TonyG
#147
I'm using the Vette filter/regulator, so I will be using the return. I have the return line and line to rail installed. I'm just trying to make the feed line work right now. I believe I found something at NAPA that will work.
#148
I realize there aren't many of these swapped cars but is there a "best place" to find one for sale? Or the best place to find LS engines and 944s with blown engines? Problem is I don't think I could do the swap.
#150
http://seattle.craigslist.org/skc/ctd/3802054020.html
^^^ for anyone looking in the Pac NW
They want a thousand less on their website (which is in the ad)
