heather control valve - flow direction?
I'm replacing the heater control valve with a metal one (it's actially half metal half plastic now) and the new valve has a flow arrow marked on it. Does the coolant flow towards the firewall in this hose or away from the firewall?
I also poked around a local auto parts store for some different hoses and moved the location of the valve away from the hole at the top of the bell housing.
I essentially cut the hose coming out of the firewall in half and moved the valve there, then found another hose with an L bend to come around to the head. I didn't move it that far, but if it leaks at the valve it should run down the side of the bell housing instead of thru the hole and onto the clutch.
