T-Bar Delete with Roll Center correction and Rod ends. COMPLETE!
#91
I'm no engineer....but for existing units I would add a longitudinal steel to the center tube as well as a piece of 1/4" angle to the bottom of the center tube for strength. I would also weld on tabs in the center to mount to the body like the Kokeln one.
As a redesign I would simply beef up all the components, as well as add the center mouting tabs.
I sure hope someone keeps this moving forward. The 944 is an awesome track/race car and things only add to the excitement.
#92
This weekend I did 6 races (12 total sessions) on a fast and bumpy Spokane track with no issues from the rear suspension. I did keep a close eye on it though.
I won 1 race and got to within 9 hundredths of a second of the class track record. It does make a difference.
#93
My plan is to 1) hear more about this, 2) make it stronger by doing what the owner of the piece that failed suggested. I wont re-powerder coat it or paint it, maybe just a clear coat to stop rust. That way I can inspect for cracks, etc.
I think I need to install it to fit the extra tabs and check for clearance to know where to beef it up, a simple angle iron on one edge would probably do the trick with the tabs added.
900 rear springs, 400 HP so Im in the same boat
#94
So we know of at least 3 cars out there racing these. Any more? Only one failure so far.
#96
Rennlist Junkie Forever
But...
Since race cars don't run rubber motor mounts:
P = 0
Thus Ma = 0
And if Ma = 0, Ra=0
And even if there were rubber motor mounts... the the forces we are talking about here are trivial.
TonyG
P = 0
Thus Ma = 0
And if Ma = 0, Ra=0
TonyG
Hi Tony, I know you've got a lot on your plate at the moment.
So I've attached a free body diagram to show what I mean more clearly.
Attachment 744114
From Newton's 3rd law: Ra = - P
In this case:
P = reaction force from motor mounts due to applied axle torque Ma
Ra = reaction force from trans mount due to reaction force P
(of course, these forces are only about 170kgf, so equivalent to about a 3g loading)
With compliant mounts, this would result in the motor moving slightly upwards, and the trans moving slightly downwards.
Cheers,
Mike
Attachment 744114
In this case:
Cheers,
Mike
#99
F=-kx and all that. (Mr Hooke and Mr Newton again). Solid mounts don't eliminate forces, or moments!
(I know this stuff pretty well, even though I wish I was as good at my job as you are at yours )
Agree with you that the forces are trivial, which still begs the question: short of running over the crossmember with a forklift, what could possibly cause it to fail like that? Any new ideas?
Cheers,
Mike
#100
By the way, there is a 968racer here which also uses this torsionbar. No problems at all, but i'll address this problem to them, maybe they have some extra input on this issue!
#101
Hi Tony, since I'm a pedantic mechanical engineer, I'll just mention that the forces and moments are unchanged, irrespective of rubber or solid mounts - it's just that the displacements are different.
Cheers,
Mike
Cheers,
Mike
It's hard to tell from the pic, but it sure seems that either the car hit something, or one side of the suspension carrier came loose from the body, which then had no support and bent. But even then it's hard to imagine the tube bending like that.
Once it started to bend even a little, the rear alignment would be so far out that you'd know there's something drastically wrong and would pull in to the pits.
How you could keep driving to the extent that it was deformed like that is very strange.
TonyG
#102
Be good to get more pics from the OP??
#103
FYI.... I can get Vision to make some of the rear suspension units if anybody is interested. But they get about $2k for the setup. And no... they won't fail.
TonyG
TonyG
