TonyG > New Race Car Build Thread
#1337
Awesome bit of kit! I know how much these are. How much to ship though?
#1338
Location: Bangkok, Thailand, Milpitas, CA & Weeki Wachee, FL
1 Post
Guess that is why they tried to get me to buy this, came quickly and looks great. Still waiting on my 968 gears. Every other month when I ask for an ETA it is 4 weeks.
#1339
Rennlist Junkie Forever
Well the good thing is you're working on about $1.25c exchange rate US to Au $. But it's in no way a bolt in proposition. Requires total cut and fab job plus all the other driveline components. Good thing is that you will have much stronger axles/CVs etc. These things are built to run some serious tq. They're the control 'Box in the Aussie V8s.
#1342
Really? Odd??
The transaxle comes with a CNC adapter plate, so it bolts straight up to the 944/968TT. And it comes with the correct input shaft splines, so you use the factory coupler. So the only thing you have to do is to hang it in the back. I don't know about the clearance issues of a stock car, but it's not an issue for me. But fitting it into a stock body car w/o a stock fuel tank shouldn't be major surgery.
I specified 996TT drive hubs, so I use 996TT CV's on the inner and outter axles. My only real fabrication issue is having to have custom length drive shafts.
TonyG
#1343
Getting new trans fitted... The trans is not at the installed height in these pics. At the right trans height, the axles are about level when the car is on its wheels.
BTW... stock 996TT axles fit perfectly.
TonyG
TonyG
#1344
That is what you call "EYE CANDY" Looks great and I am amazed the axles fit. How did you manage that magician trick, nothing ever seems to fit exactly when you make these kinds of mods.
#1345
Yeah, that is pretty amazing!
#1346
Hi Tony,
Amazing build and parts!
Guessing the drive shaft fitment is good with the new clutch pack?
Cheers,
Constantine
Cheers,
Constantine
#1347
The only difference was the throwout bearing assembly as it's specific to to a C5 running the mini twin clutch (which you see in blue).
Anyway, thanks for all our help on the new TT. Looked great (which you can see in the pics).
TonyG
#1348
Hi Tony,
Noticed all the non-stock gear in there and was hoping the disks and pilot bearing fitment were all good for a stock drive shaft configuration.
Sometimes the clearances are not correct in V8 conversions and the drive shaft gets chewed up.
I'm sure with this level of work, everything is being looked after.
Can't wait to hear about your drives on the track!
Have fun,
Constantine
Have fun,
Constantine
#1349
Any more detail on the TTube?
