TonyG > New Race Car Build Thread
Old 09-15-2012, 05:36 AM
  #106
flipo
flipo's Avatar
Tony gongratz on you're buildt I absolutely love it , what is you're main reasons to convert the front suspension to 996 type?
keep posting pics!!!!!
Old 09-15-2012, 12:29 PM
  #107
TonyG
Rennlist Junkie Forever
TonyG's Avatar
Thanks for the compliments!
As far as the 996 GT3 front suspension goes... there's a million reasons...
Ability to adjust track width and vehicle wheel base are two important reasons.
The whole geometry of the front is totally different.
Corrected roll center.
The wheel bearings are much larger.
Less unsprung weight.
Factory fit 15" front brakes.
The list goes on... It's not cheap. But on a car like this it's worth it.
TonyG
Old 09-17-2012, 10:17 PM
  #108
TonyG
TonyG's Avatar
Getting closer....
TonyG
Old 09-17-2012, 11:07 PM
  #109
mikey_audiogeek
mikey_audiogeek's Avatar
Nice work Tony!
What's the part number on those spindles? They're different to mine.
Cheers,
Mike
Old 09-18-2012, 12:21 AM
  #110
333pg333
333pg333's Avatar
They're all Cup or custom. What parts do you have Mikey?
Old 09-18-2012, 01:33 AM
  #111
TonyG
TonyG's Avatar
Originally Posted by mikey_audiogeek
Nice work Tony!
Cheers,
Mike
Which spindles? The 996 spindles? If so they are 2004 996 GT3 spindles.
TonyG
Old 09-18-2012, 01:46 AM
  #112
95ONE
95ONE's Avatar
That pic still shows a bit of bump steer correction is needed. From that angle anyway. I see they welded in the old mounting hole and made a new one higher up. Looks pretty nice. I can't wait.
Old 09-18-2012, 01:54 AM
  #113
333pg333
333pg333's Avatar
In trying to ‘cure’ bumpsteer I was under the impression that the arms and tie rod were meant to be working as parallel as possible? I realise that the inside fixing point of the arm should be raised on our cars if possible, as shown on Tony’s car.
Old 09-18-2012, 02:33 AM
  #114
Olli Snellman
Olli Snellman's Avatar
Nice progress Tony.
How about control arm length compared to original 951 one? Would be quite simple to develop a kit for 951's using 996 parts, which are available for a good price.
Old 09-18-2012, 02:29 PM
  #115
Chris Prack
Chris Prack's Avatar
Very cool Tony. I know Joe and am really happy to see the car going back together. Good luck the rest of the way. Can't wait to see the final product.
Old 09-18-2012, 02:48 PM
  #116
Scott H
Scott H's Avatar
Originally Posted by TonyG
Getting closer....
TonyG
No front brakes. Bit of a ballsy move, but I like it.
So toe would be adjusted normally, camber by adding/removing shims, and caster by the rod going to the control arm?
Old 09-18-2012, 03:56 PM
  #117
Jeff951NJ
Jeff951NJ's Avatar
WOW I love it!! What are you going to use for a front sway bar and how are you going to mount it?
Old 09-18-2012, 04:01 PM
  #118
Chris Prack
Drop link is already hanging there.
Old 09-18-2012, 09:07 PM
  #119
mikey_audiogeek
Heh heh... was doing something similar, going a slightly different path now. Photos to follow
Old 09-18-2012, 09:19 PM
  #120
TonyG
TonyG's Avatar
Close... the caster is also controlled by the camber plate. Additionally, you can lengthen or shorten the wheel base by the drag link & shim combo and/or increase the track width by adding shims.
There is adjustment everywhere in every way.
TonyG
Quick Reply: TonyG > New Race Car Build Thread
