TonyG > New Race Car Build Thread
#1127
Rennlist Junkie Forever
Possible but you will need to cut up the floor and back seat area to fit the front of the transmission.
You might as well look into fitting the Corvette torque tube as well as it's in aluminium and lighter than the 944/968.
#1132
Team Owner
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
I surmise you're in 3rd, 4th and 5th 98% of the time, and it's well known the ratios on the '68 box are all but useless for racing a v8...
still, I'd love to see if it would break from your regular driving.
#1133
From experience, My C5 6-speed trans and torque tube is 78.375" from axle centers to BH mating face....
944 is....77.18"
I have built a few sets of axles for the 928 6 speed swap, including my own 1GZFE V12 project and the outboard 944 stubshafts would only need a set of CV adapters. A couple members on hybrids (Kevin924Kevin comes to mind) have done the swap using thefactory steel torsion tube. It needs to be chopped and "horseshoed" while removing torsion bars and adding coilovers. Or similar to Tony's build here the torsion tube can be tossed for a double wishbone suspension. Lots of work but well worth the effort. The carbon synchros are smooth as butter and even a supercharged V8 wont pop anything on a stock box. Not to mention the F1 weight distribution when the heavier weight is transfered to back.
944 is....77.18"
#1134
944 is....77.18"
944 is....77.18"
#1135
But the Vette guys break these transaxles too. I see quite a few of them being replaced on race cars at the shop that does my GM engine work.
If you're out there drag racing the car.... I don't care what transaxle you use, it's gonna break.
TonyG
#1136
I'm in 3rd, 4th, and 5th 100% of the time unless I'm in the pits.
1st and 2nd gears are a part of the input shaft and the gears are just to small to handle considerable torque.
That said, the only 951 transmissions I've blown since 2006 on the race track are two.
1. The stock LSD case split in three pieces (these pieces are welded together) which moved the ring gear and took out the pinion gear and more. This can't happen with a Guard LSD.
and
2. Took out 2nd gear at Laguna Seca. I knew not to use it and I did. So it's no surprise that it stripped the teeth off 2nd gear.
So with a big TQ V8 and the fact that you can run the car competitively in 3,4,5 gears, why bother with a Vette transaxle?
As far as axles go, I run 996TT axles and CV's. The only thing that's modified is the transaxle stub axles being machined and drilled for the larger 996TT CV bolts, and using BoxterS outter CV races on the tranaxle side. This setup is known to be "bullet proof" on the super high 996/997/Cup race cars.
TonyG
and
TonyG
#1137
My interest in a Corvette setup would be to include the suspension, not just the gearbox. While your build and Dukes with not dissimilar suspension is fantastic, ideally if you were to go with a blank sheet of paper you'd want suspension with longer arms/levers than a rear engine Porsche can fit. Might be being picky but the longer levers should keep the wheel in a more vertical state for more of the time compared to the shorter Cup levers. Of course the Cup suspension has had a zillion dollars spent on it over the years in terms of R&D but you'd also think that there would be a fair bit of time spent on the Vette rear end. Plus assume parts would be considerably cheaper. Overall a full Sequential gearbox would be better still but there's a limit to expenditure and one has to examine R.O.I. before making such leaps!
#1138
The guy that used the Vette transaxle used the Vette rear suspension too.
It never worked out. The roll centers were all wrong. The car had to be run up high in the rear to make it turn properly.... which it never really did.
I'll post pictures soon.
TonyG
TonyG
#1139
Rainman
My interest in a Corvette setup would be to include the suspension, not just the gearbox. While your build and Dukes with not dissimilar suspension is fantastic, ideally if you were to go with a blank sheet of paper you'd want suspension with longer arms/levers than a rear engine Porsche can fit. Might be being picky but the longer levers should keep the wheel in a more vertical state for more of the time compared to the shorter Cup levers. !
i can understand the longer arm = more vertical tire on a swing axle but with upper/lower unequal-length links is there really much more to gain?
#1140
He finally gave up.
TonyG
He finally gave up.
TonyG
I'm probably looking at it too basically but I'd still think longer = better in theory.
