TonyG > New Race Car Build Thread
Old 11-28-2013, 01:41 PM
  #796
Chris White
Rennlist Small
Business Sponsor
Chris White's Avatar
'Front panel designs' is the way to go for switch / gauge panels.
Originally Posted by TonyG
Update.... 11/27/13
The wiring is almost done. This was a big job to get this thing wired.
We still have to program the Racepak dash and the Smartwire (PDM) and calibrate fuel levels in the fuel cells. And we filled up both fuel cells with fuel from empty. It holds exactly 51 gallons in both fuel cells. That will give us our full reading. Next we well pump it out with the fuel pumps and see exactly how much comes out....
I need to get some laser engraved name plates for the switches.
The switches are:
Ignition
Fuel pump
Transfer pump (momentary)
Exterior lighting
ABS w/ warning light
Power Steering w/warning light
Cool Suite 1 & 2 (up/down)
Interior lighting (high and low)
Engine start
Fire suppression
The Smartwire will automatically attempt to reset the ABS or Power Steering pumps if a failure is detected (or it can be done manually with the switches on the dash).
The Transfer Pump will transfer fuel for a preset amount of time (probably like 2 minutes )
TonyG
Old 11-28-2013, 03:15 PM
  #797
TonyG
Rennlist Junkie Forever
TonyG's Avatar
I totally agree. I think once it's done I can pull the panel and send it off to have an aluminum overlay made.
TonyG
Old 11-28-2013, 03:31 PM
  #798
333pg333
333pg333's Avatar
Looks beautifully prepared and worth the wait. Having sub standard wiring in this car would have been a let down. Thanks for reminding me about the panel as well. Need to get mine done.
Old 11-29-2013, 08:02 PM
  #799
URG8RB8
URG8RB8's Avatar
Location: Bangkok, Thailand, Milpitas, CA & Weeki Wachee, FL
Forgive me if this has been covered previously, but I am curious how difficult it was to invert the intake. This is the first LSX install I have seen with this orientation.
Old 11-29-2013, 09:16 PM
  #800
TonyG
TonyG's Avatar
You simply unbolt it and bolt it on the other way. No modification necessary.
TonyG
Old 11-29-2013, 10:33 PM
  #801
URG8RB8
URG8RB8's Avatar
Wow, that is cool! Do you think this was intentional or an accident. Would there be any reason to invert it on a Chevy?
Old 11-29-2013, 11:44 PM
  #802
TonyG
TonyG's Avatar
Honestly I really don't know. There's no real reason that the intake has to point forward to begin with, and I can see where in certain conditions, in certain vehicle configurations, it might make sense to flip it around.
But in the end, I think it's a function of the symmetry of the ports and their respective bolt patterns, and that it just so happens that you can flip it around.
For me it allowed me to use the water pump I wanted to use (which is far better than anything else out on the market), eliminated me having to figure out how to run a 4" tube out to the front of the car (which would have interfered with my radiator setup), and ..... as a side bonus, reduced the intake noise that can be picked up by the noise ***** at tracks like Laguna Seca (believe it or not... intake noise is just as much a problem as exhaust noise on tracks where the DB limit is below 97db).
TonyG
Old 11-29-2013, 11:49 PM
  #803
URG8RB8
URG8RB8's Avatar
Now you also have cowl induction, Ha!
Old 11-29-2013, 11:54 PM
  #804
TonyG
TonyG's Avatar
Exactly. In a nice high pressure zone :-)
TonyG
Old 11-30-2013, 12:05 AM
  #805
URG8RB8
URG8RB8's Avatar
Exactly. In a nice high pressure zone :-) TonyG
Are you going to have a modified "Cowl induction" hood, to maximise this added benefit? Seeing how perfectly everything else is executed, I would assume so.
Old 11-30-2013, 10:30 AM
  #806
disasterman
disasterman's Avatar
Reversing the intake solves a number of housekeeping issues. It allows a number of options in the front, sloping radiator, reduced weight etc. The intake air temperature is also reduced somewhat by pulling air further away from the track surface.
Tony's build has a sealed box/chamber. I have the same set up, it breathes very well and the air is cleaner.
Old 11-30-2013, 07:12 PM
  #807
PJR1976
PJR1976's Avatar
Question on the reverse head/air intake.... any issues with water pooling from the windshield runoff? Did you guys make any accommodation for drainage or do you simply just not drive in the rain.
Old 12-02-2013, 09:10 AM
  #808
disasterman
Rain has no affect, if anything cowl induction is less affected by rain. Race cars are moving, rain goes up the windshield not down.
Old 12-02-2013, 10:02 AM
  #809
Chris White
Rennlist Small
Business Sponsor
A little rain water getting sucked into the engine does not hurt - in fact it may up the HP just a little.
Short of running a garden hose into the intake the volume of water to air is so small it makes no difference. At full throttle Tony may suck in up to 600CFM....think about it, that's 10 cubic feet per second. A couple of drops of rain water won't hurt.
The only two reasons to not drive in the rain is fear and not wanting to clean the car afterwards!
Old 12-09-2013, 03:26 AM
  #810
Domkouki
Domkouki's Avatar
jeff jordan is doing your wiring?
Quick Reply: TonyG > New Race Car Build Thread
