TonyG > New Race Car Build Thread
#650
Rennlist Junkie Forever
Yes. Full undertray (flat bottom) with diffuser.
The front splitter (not shown in the pics) runs all the way back to the engine cross member.
The rest of the undertray will go from there backward.
But to start, we're not going to run the undertray because it will slow down the setup time considerably. Only once the car is setup will be finish and install the rest of the undertray.
TonyG
TonyG
#652
The front end issues are resolved without having to use those rack extension things. It required a completely different front sway bar setup (to get it out of the way).
But the deal with the 996/997 uprights is that they are designed with an angle on the bottom. The A arm has a matching angle. Because of this, the A arms don't run parallel to the tie rod.
TonyG
#653
The front end issues are resolved without having to use those rack extension things. It required a completely different front sway bar setup (to get it out of the way). But the deal with the 996/997 uprights is that they are designed with an angle on the bottom. The A arm has a matching angle. Because of this, the A arms don't run parallel to the tie rod.
TonyG
TonyG
Jeff
#654
Tony, since the A arms and tie rods don't run parallel to each other, does this mean your new setup will have a certain amount of "bump steer"? Or, are you saying there is something about the way the 997 uprights have been designed to attempt to remove the "bump steer" effect even though the A arms and tie rods don't run parallel to each other?
Jeff
Jeff
They don't run parallel because the A arms in the 996/997 aren't designed to parallel to the ground.. or to the tie rod. This is because they have a bend in them. They are not straight. And if you look, the bend is at the end, where the upright bolts to the A arm. There's about a 20+ degree angle (eye balling the angle).
This means that the A arm is designed to run at a downward angle (down hill towards the wheel). This puts the tie rods and A arms at different angles and not parallel.
See this example. Note the angle at the tie ball joint.
What counts in the setup of the 996/997 front suspension is that the area around the ball joint on the A arm be parallel to the mating area on the suspension upright. That puts is "centered" in it's travel range.
The tie rod won't be parallel.
But because of this, your ability to change your ride height with your spring length (or spring collar) is limited. The A arm angle to the upright has to be very close to parallel.
And... this is why Porsche has so many different uprights for the 996 and 997.
TonyG
#655
Yesterday's update... more small stuff
It's almost time for electrical... woo hoo...
TonyG
TonyG
#656
Epic! Not sure how you can afford this and all the drinking you seem to do???
#658
Note... the shocks are just mockup shocks.
The new JRZ's will be installed later this week with the new 2012 997 Cup Uprights
Yeah..... hopefully this thing will run soon...
TonyG
TonyG
