TonyG > New Race Car Build Thread
#376
Rennlist Junkie Forever
lol...having said that, I'm sure I've seen sequentials for other brands of cars for considerably less. Subaru WRX for around $10k i.i.r.c.?
#382
And if I were to do a custom trans, it would be very expensive because it would be a PDK. And that would be at least a $25k add-on. And the reliability isn't proven under high HP applications in a racing environment, no known hours per rebuild, and no known rebuild costs (which we all know wouldn't be inexpensive).
And if it's not a PDK, then what's the point?
TonyG
#383
Even a stick shifting sequential is a clear advantage over an old 951/968 box. Not that a paddle shifter wouldn't be better again. Fast, but somehow not quite as satisfying as a stick shifter in my opinion.
Hey did you get my email re the Canards?
#386
I've been racing with over 450RWHP and 400RWTQ (slightly less several years ago) with 315 sticky tires for over 7 years and have only broken two transmissions. The first had the factory LSD case break, and the second was when I broke 2nd gear at Laguna Seca.
Now I run a Guard diff which will never break like the stock LSD (because it's 1 piece vs the stock which is 3 pieces) and I never use 1st or 2nd gears on the race track (which are very small and are a part of the input shaft).
The only down side to the transmission is the fact that it shifts slow compared to a sequential no-lift transmission. The stock gearing is pretty good all-around gearing, plus there are custom 3,4,5 gear ratios that are available for about $600 each.
TonyG
#390
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
