TonyG > New Race Car Build Thread
Old 01-03-2013, 12:11 AM
  #286
TonyG
Rennlist Junkie Forever
TonyG's Avatar
Originally Posted by BC
Is there a diagram of that TT v6? That will need e85.
The engine makes 420hp at the crank stock, through stock exhaust, intake, and turbos.
Another 100hp is easily accomplished on pump gas when that's your starting point.
And no... E85 is out of the question. No need, expensive, unavailable, and not fuel efficient for endurance racing.
Pump 91 octane crap gas all the way baby!
TonyG
Old 01-03-2013, 12:24 AM
  #287
NZ951
NZ951's Avatar
Thats whats holding me back from E85, not so much the cost but I would need a 200lt tank for endurance racing!
Old 01-03-2013, 01:06 AM
  #288
TonyG
TonyG's Avatar
Not only will you need more capacity, but potentially the size of the fuel lines and the delivery rate of the fuel pump could very well need to be larger as well.
I've heard you need another 35%+ greater fuel capacity and delivery rate. Plus any other parts that need to be converted due to fuel system compatibility.
You need more fuel capacity? Heck... I can barely do with 54 gallons of gasoline. E85 would make me do another fuel stop (at least).
TonyG
Old 01-03-2013, 01:31 AM
  #289
NZ951
NZ951's Avatar
TonyG
Yup true... and then there is draining the fuel out after the race if your car is sitting around... PITA.
Old 01-03-2013, 04:37 PM
  #290
TonyG
TonyG's Avatar
Today's update...
Flipped intake, laying out heat exchangers.
TonyG
Old 01-03-2013, 07:24 PM
  #291
Steve113
Steve113's Avatar
Damn its coming out way to nice to race
Old 01-03-2013, 07:51 PM
  #292
333pg333
333pg333's Avatar
Meh...piffle. The benefits of running E85 far outweigh the negs...but I can see if you're doing endurance racing then the extra fuel needed would be a matter for consideration. Depends on what time advantages you can gain by running extra boost vs 91 pump. I'd be guessing in the region of at the very least 5 psi which over the course of lapping might warrant it?
Old 01-03-2013, 07:58 PM
  #293
BC
BC's Avatar
I said ethanol. Not methanol.
Old 01-03-2013, 07:59 PM
  #294
BC
BC's Avatar
TonyG
I'll drop it. Need? Can't argue that without knowing more. Expensive? Less expensive than 91 octane in San Diego. Unavailable? Maybe. I would assume you would buy it in large quantities.
Endurance racing I can see your point.
Old 01-04-2013, 10:22 AM
  #295
PorscheDoc
PorscheDoc's Avatar
Hey Tony,
Can you shoot a picture of your brake master setup? I don't recall seeing that in the previous pages, though maybe I missed it. I see it mounted in the old fuse box location. I assume it is an entire pedal assembly system? Just curious to see how you are doing it!
Old 01-04-2013, 10:23 AM
  #296
disasterman
disasterman's Avatar
Cowl induction - Coooool!
Old 01-04-2013, 04:42 PM
  #297
333pg333
333pg333's Avatar
Bit confused about this flipped intake which I presume involves the cowl induction? Where does it go from here?
Old 01-04-2013, 06:11 PM
  #298
odurandina
Team Owner
odurandina's Avatar
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
we like.....
http://www.vetteweb.com/tech/vemp_12...s/viewall.html
"Yes, the intake manifold shown in our lead photo is backwards. That's intentional, for reasons we'll go into in a moment....."
Old 01-05-2013, 02:26 AM
  #299
TonyG
TonyG's Avatar
Today's update... courtesy of your local Vision Motorsports race shop.....
Cowl Induction. This is only a mockup and is not done.....
Credit to: disasterman for the idea
The main reason we did it is to not have to interfere with the radiator ducting.
TonyG
Old 01-05-2013, 02:27 AM
  #300
TonyG
TonyG's Avatar
Originally Posted by PorscheDoc
Hey Tony,
See below
Tilton 620 pedal assembly with the master cylinders on top of the assembly instead of in the engine compartment.
TonyG
Quick Reply: TonyG > New Race Car Build Thread
