Refresh951's Hybrid Stroker - A Blown944 Design
#77
Since Sid holds the patent on this stroker concept I assume you be including royalty fees in your final build costs?
I really do enjoy reading these build threads as I am a major fan of doing things differently. Sid's a good friend and seeing his evolution in the Porsche realm makes me wish he would start playing with Audi's.
#78
Finished claying the valve clearance last night. This motor will NOT be a zero interference design. I will be using a head with 47mm intake valves (+2mm) and as you can see from the photo below the intake valve touches the valve relief in the piston. The exhaust valve was fine. I will be claying the stock head in the next couple of days to see if fly cutting will be necessary for zero interference.
With the timing belt on, I had about 0.060" clearance worst case which will be fine. I have had enough delays and will be moving forward without fly cutting on this build.
#79
Wow Shawn It's looking really good! I've enjoyed following your build.
I work with a guy from Savanah and we're planning a trip down to GA. I want to see this thing in action!
#86
Duke, Since Shawn didn't answer.
The sleeves do go to the top of the deck surface. Maybe you're meaning the pistons? I think his is down in the hole .015 iirc. Mine on the other hand
However, now that you made me look close at it, I am a bit concerned that the broach marks are too deep for the MLS gasket. I do wish I had seen that earlier. I hope it seals well.
#87
I looked at it very closely and I am sure it will be fine. Not sure why my machinist put the chamfer at the top, I will ask him next time I am over there.
The fact that I am using the 103mm Cometic and the bore is 102.3mm buys a little room. I did a a lot of measuring when I installed the Cometic to make sure the seal looked good on the deck.
