Refresh951's Hybrid Stroker - A Blown944 Design
#271
My current plan is to drive my car for another month then winter will be here and I will parking the 951 for a few months. During this time I will pull my motor, tear it down and inspect it for any issues.
Then I will be changing the crank to an offset grind 3L crank, changing the pistons, and changing turbos. I have run all the numbers and everything looks good. Updated motor will be a 3.15L with 8.27 CR and will be non-interference (wo fly cutting).
These changes will be pretty cost effective as I am only replacing changed components. Block will be unchanged. I will also be installing my refurbished wiring harness.
#273
Dude, you are on it!!
Can't wait to see how it works out. That is my plan too, but I may focus on some other things first.
The torque should be over 500lb ft for a wide power band too.
I'm anxious to see it come together for you..
#274
So how about after inspection putting it back together and building a second motor? Sell the first???? If the current motor turns out to be good upon inspection. Seems a shame to not build a second....but thats just me and of course I there maybe good reasons to do what your planning not judging just throwing out the question.
Jason
Jason
#275
Jason
Jason
#276
Ah good to hear. I just emailed a PC member here in Calgary....Going to try out the route you guys have gone.....400.00 for pistons makes me smile and I'm assuming thats for 8 pistons. It snowed here so cars are parked
Jason
Jason
#279
Are you racing me or something..lol..
Nice pickup.
Remember, you may have to take some material off the counterweights depending on the pistons.
There are a couple other things too. I'm sure we'll be talking soon.
Anyway, this is awesome!!!
Nice pickup.
#281
I am excited about it. Having a blast and need to make sure I don't get ahead of myself.
#284
Rainman
Where did you source your sleeves from? You said they were like $20 apiece and generic...I contacted Darton as they are local to me and just the sleeves for a 944 unfinished at 101.5mm is $800 for the set of 4, and another $750 to install...
#285
Basic iron sleeves, my machine shop supplied them. The are a common item. Ask your machinist, if you are using a knowledge shop the will have a catalog.
