High Flow, Low Cost, 8V Cylinder Head Project
#61
#63
Had some time to kill so I worked out a cheap way to hone the stock intake manifold. I used a $2 flexible bolt retriever (hacked up) from Harbour Frieght and a roll of 80 grit emory cloth to make a flexible "flap wheel" as shown below. It is not quick but pretty happy with the results. I have no problem running through the runners around bends. It is doing an effective job at cleaning up the surfaces.
#66
My High Flow Head Project is complete. We used a mill to do a bit of un-shrouding of the intakes as shown below.
The guy who is doing the flow testing for me on a SF600 is on vacation this week so the flow testing will be done next week. The plan is to do testing as follows:
25" (water column) at 0.472 Intake lift and 0.437 Exhaust lift to compare with some data posted by m42racer on a stock head. The testing was performed by Performance Developments.
28" (water column) at 0.480 Intake lift and 0.480 Exhaust lift to compare with some data posted by LR website for different performance heads.
I will post the flow results in this thread. I do not have all the machining costs as of yet. When I do, I will post the final cost breakdown.
#67
Great work and thanks for the updates. Be great to test the stock intake on this head too?
#68
Shawn try to do some lower lift numbers as well. Ie .050,.100,.250
It would be nice to see how they look with the larger valves. If you need a stock head to compare with on the same bench I can send you one.
#69
23.1 29.8 19.9 24.7
47.0 56.0 44.6 55.1
77.7 87.8 70.6 86.2
105.8 116.3 93.8 109.0
133.7 143.6 105.8 116.8
147.6 161.3 121.7 134.6
162.3 174.2 132.9 144.8
171.0 187.2 143.8 157.2
178.7 196.8 149.4 163.6
186.7 202.9 151.2 166.8
This was done on a SF600. I was thinking if I had it done on the same model Super Flow bench, I could use his data for comparison?
#71
Shawn, sent you an email.
#73
^^Interesting read. Just getting into it, but a quick question. Am I to understand that he got 298cfm on the Intake of a 2 valve head? Is this to be directly compared to our 2V heads? How has he achieved this figure which is waay higher than our best? (Approx. 250cfm) Just doesn't seem feasible??
I shall continue reading the thread...
#74
928 Euro S heads are probably pretty comparable to a 944 head. The fellow doing the work is a real phanatic and creditible. He had posted some pictures but it was so long ago they no longer are there. I imagine he would be more than happy to forward them as he always shared his ideas.
#75
Interesting post on Pelican that he referenced:
http://forums.pelicanparts.com/911-e...-dark-art.html
