Rim Widening?
Rim Widening?
Is it possible/plausible to widen a stock rim rather than buy a new or different style rim?
I like the rim style that I have but they are narrower than my stock one's and I would like to widen them to the stock width up front and a little wider in the rear. My stock rims are 16x8 front and 16x9 rear. My current boxster rims are 17x7 and 17x8.5.
I believe it's called pico tire and wheel in Los angeles. I'm taking the rims for hotrod to get widened. Car craft magazine did a big article on them for one of their project cars and had their rims widened
If you are looking for pricing, fill this out for a quote. I would think it would be easier to just buy a used set.
http://weldcraftwheels.com/index-7.html
Some years ago I had a pair of my Jalpa wheels widened from 7.5” to 10” by Eric Vaughn: (626) 358-6413, Monrovia, CA.
The widening is inwards, which is easily compensated for with spacers (and longer bolts) to get the right offset.
Laust
Laust
Rennlist Junkie Forever
Scroll across until you see the picture of a widened polished wheel. Look at the welds. Wow.
And BTW, I would never drive a wheel that was butt welded and welded by hand. EVER.
TonyG
FWIW... if you wide your rim, you need to get somone that supplies a new barrel that is slip fit over the cut down wheel, then welded on both sides of the overlap (after it was been trued).
The crap I see on Weldcraft is downright scary looking.
TonyG
TonyG
