Why can't the 951 do well in autoX?
#62
Omni, that camera angle makes me feel like a midget strapped to the floorboard in the back trying to see out the windshield. Maybe set the camera higher/forward for a better view of the road?
#63
Thanks for sharing the videos, some of those courses looked pretty fun. Ours use TONS of cones to form a sort of go-kart track with boundaries set by cones on either side, and are very tight, it's harder to make your own line than in the more free-form course that seem to be the norm. But, it makes for a unique challenge and my near-stock '86 acquits itself well!
#64
This year I have a 2nd camera. I'll have one cockpit mounted and one mounted on the windshield. I like having the cockpit cam so I can see the gauges, the wheel, etc. 1080p cockpit cam means I can zoom in pretty nicely on the gauges.
#65
We won't be going back. Lot was just too damned small.
The first one of the 2012 season is this coming Sunday - lot is HUGE. Extra bonus points is that our AX coordinator is out of town, so her husband and I are "subbing in." She's also usually the "voice of reason" when it comes to course design. She's gone... so we're planning to build a pretty wicked fast course.
#66
I see. I have found that the windshield location isn't great either as it limits the left to right view, and it's hard to tell what the driver is or isn't doing to make the proper line towards the apex. Therefore, it's hard to critique. - This is what I've found when trying to go through my own footage.
#67
You guys have some interesting autoX setups, Ill bet the 914 guys loved the first layout.
#68
You guys need to get your local clubs into Auto-Xing. When it is set up right it is a down right blast.
Pro Solo is one of my favorite forms of racing. For those of you that do not know what this is: It is side by side Auto-X racing on mirrored courses. Left side vs. The Right. Then you switch..
#69
#71
You guys remind me of two reasons why I don't bitter trying to be competitive at autocrosses -- the launch at the start and those painful 2-1 downshifts.
It's worth noting that most pca groups I've run with use a 'clutch saver start' where the timing light is after a kink in the start, thereby allowing you to save the clutch.
Unfortunately the autox I went to two weeks ago, while fun, was not such an event and i wound up making the conscious decision to just dog the start.
The other object of annoyance (for me at least) is the fact that I hate downshifting into first gear (yes, I do double clutch and it still makes me feel bad). These gearboxes are old enough and I'm trying to get mine to last as long as possible!
The event I went to a couple weeks ago was quite fun, despite the fact that I dogged the launch and didn't bother downshifting into first. The funny thing was that I still wound up winning my class and was only 3.5 sec off FTD! :-)
#75
1->2 upshifts don't NEED to be lightning quick. The time you save by ripping it into gear is minimal. I always granny shift (I don't want to hurt my trans either!) and generally as long as you launch smoothly and gradually load the axles (vs. just popping the clutch and sending a shock of torque through them) you shouldn't have any problems. In a previous life I was pretty hardcore into drag racing and have gotten pretty good at keeping transmissions, rear ends and axles together over many hard launches.
